JMB RetrofitsVolks Autos
Thread: leaking roof
    fkr
    Aug 2012
    leaking roof
    hi all looking for help. just got a 5 yr old a4 cabriolet. hadit week and the roof has leaked . has anyone else had this problem?what can i do ?
    ROB A4 CAB's Avatar
    Aug 2012
    swadlincote
    21
    hello fkr i had the same problem i was parked on a slope in a heavy downpour and my roof leaked on the front drivers side at the top of the a pillar theres a rubber seal down the a pillar with a hole forming a drain channel to the base of the pillar i just slowly and carefully poked a long piece of stiff wire down the hole to clear a blockage.i then cleaned and reproofed the whole roof using a cabriolet cleaner by autoglym no problems since hope this helps
    fkr
    Aug 2012
    Quote Originally Posted by ROB A4 CAB View Post
    Thanks, going to take it back today and ask them to do the above, hopefully this sorts it for me too
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Cleaning and sealing is a must is water doesn't bead on the roof. I used autoglym the first time I did it, did the job but I've been told 303 cleaner/sealer is a much better product, so I'd recommend that.
    If you actually read the A4 cab handbook it says some water ingress is normal...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
  1. A4 cab slight leaking roof
    By lewie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th February 2014, 18:57
  2. Replies: 13
    Last Post: 10th August 2012, 21:45
  3. My bloody roof is leaking!
    By Big_Dave in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th November 2011, 17:58
  4. Arrrh cab roof leaking!!
    By stone_uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2010, 21:59
  5. Roof leaking any suggestions ??
    By AdamCarey in forum Classic Audi Forum
    Last Post: 24th November 2006, 15:12
