Badger5Chris Nott
Results 1 to 11 of 11
    Jan 2011
    111
    Wheel offset question
    I know this may sound stupid to those who know but, which way does the offset work? my wheels are et35 which has been fine until i fitted new pads, then they hit the carriers! I have now fitted 5mm spacers so I assume I now have et40?? I ask this because my wheels fill the arches right to the edge and if i change the wheels to et45 as standard it seems they would almost be proud of the arch.
    Thanks, Phil
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,662
    The thing with offset is, it's kind of the opposite of what you expect it to be. The lower the ET number, the further out the wheels and tyres sit. So, ET45 wheels sit 10mm further in than ET35 wheels. If you are using 5mm spacers with ET35 wheels, your effective offset is ET30, not ET40.
    Slightly counter-intuitive, but that's how it is.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Jan 2011
    111
    Thanks, but that now means I definitely don't want to put on std offset wheels! what is the minimum I can go before I hit the caliper again please.
    Phil
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by PhilMill63 View Post
    Phil
    That all depends on the wheel design......oh, and you want to be pushing the wheels out to fill the arches, not have em as close to the calipers as you can
    Jan 2011
    111
    I like the older RS4/TT wheel, I think its AVUS? based on that wheel can I use the 20mm offset RS wheels????
    Thanks.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,662
    Thanks.
    I've no idea. Probably, I guess, but they're sure going to stick out a lot.
    Sep 2012
    34
    Okay so I've lowered my car 35mm and I'm on factory alloys at the moment (that will change). I was wondering what offset the factory wheels have.. Any Ideas?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,662
    Quote Originally Posted by Muzzcuzz View Post
    Have a look at your spare wheel. The offset will be stamped on the inside of one of the spokes.
    Sep 2012
    34
    I would but I've got a space saver. =/
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,662
    It's a pain, but at least you can jack it up and pop one of the wheels proper off.
  1. Wheel offset question
    By Blackie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd March 2011, 22:31
  2. Wheel offset question
    By Audijarvis in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2010, 09:36
  3. Quick Wheel Offset Question
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 20:19
  4. Wheel offset question
    By Syncopix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th March 2010, 19:10
  5. Wheel Offset Question
    By Hatmeow Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th May 2007, 16:19
