Chris NottSky Insurance
Results 1 to 33 of 33
    Feb 2012
    58
    Cruise Control Problem, just not having any luck with this car at al
    Ok, Yesterday everything fine do a lot of motorway miles and use the CC quite often. It was fine yesterday but when I came to use it today nothing,yada zilch! checked that it wasn't in the off postion and then after getting home took the car out on the motorway again, still nothing dead as a dodo.
    So question is, does this just need recoding or is their something more sinister a foot, that is going to cost me?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    821
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Could well be something which the cruise control system uses, like a brake pedal switch or clutch pedal switch perhaps? Get the car scanned using VCDS and it may well give you a clue as to where your problem is. Does the cruise light come up on the dash or not?
    Feb 2012
    58
    Quote Originally Posted by A4_MaJiK View Post
    Thanks for the reply No no light at all which is what gave it away in the first place as soon as I press the stalk to set the speed the light normaly appears but this time not a sausage..... dont have a good feeling about this...
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,470
    its prob gona be the
    clutch or brake switch
    Feb 2012
    58
    Ok, that means a lot to me :-( what is it, and how much am I looking at to get it fixed....?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I bought a new clutch switch the other week and it was around 15 quid. Remove three bolts in the panel underneath the steering wheel, one each side of the panel and one on the side (remove the fuse box panel). Above the clutch is a white switch, around 10cm long. Disconnect the cable, twist the switch and pull out. Get the new switch, push the clutch down, hold the new switch ready in position, bring the clutch back up, twist the switch till is locks in position and then reconnect the cable.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    636
    Re: Cruise Control Problem, just not having any luck with this car at al
    If u have VCDS u can easily see if there is signal on the clutch/brake switch. Also allows you to check if the button on cruise control stalk is receiving signal.....
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Strangely enough VCDS didn't show any issues with mine.
    Nathan
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,608
    Will most likely be the Clutch Switch.
    Though as Wrath said, Ive had clutch switches work as they should through VCDS and then upon replacing it the CC works as it should..
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by jb0o View Post
    +1
    My CC had stopped working, but VCDS showed no fault codes - changed the clutch switch (took less than 15 minutes) and all is OK now.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    mechanic69's Avatar
    Mar 2007
    374
    I have similar problem with a retrofit cruise. Not knowing when the green light should come on is it when you turn cruise on or when you set the speed?
    S3 - Sprint Blue BE [MY11] My Build Thread
    Options - Satnav, Bluetooth, MFSW, Privacy Glass, Nappa Leather
    Mods - Bluefin Stage 1, DV+, Revo Race CIA, Cruise, TPMS, Bilstein B8s, Eibach Pro Kit, H&M Spacers, Exclusive Leather Trims
    Future - Downpipe sports CAT, HPFP, Stage 2+, ALK, ARB, 2nd Mortgage
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Quote Originally Posted by mechanic69 View Post
    As soon as you activate it, ie press the button at your desired speed.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    May 2012
    Kings Lynn
    896
    Mine failed to work. Audi said it needed a new clutch pedal switch as it was not working properly thus making the car think the clutch was continuously engaged. That will stop the CC working. However, I did not have it fixed as audi wanted £15 for the part and £135 labour LMAO. Ill leave it not working...
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Buy the switch and Fix it yourself its easy to do.
    F
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Quote Originally Posted by RMH1A4cab View Post
    +1
    Did mine 2 weeks ago - took 5 minutes to get the trim off, 1 minute to do the clutch switch replacement, and 5 minutes to put the trim back on.
    £135 for less than 15 minutes labour is a total rip-off.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Cruise stalk in off position - symbol off
    Cruise stalk in on position but cruise inactive - symbol off
    Cruise stalk in on position and cruise in use - symbol on
    The green symbol on the DIS comes on when you set the speed, it's on to show you that the speed is being controlled.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Quote Originally Posted by PetrolDave View Post
    That's what I meant (amended my post to be more clear) forgotten about the forward/back /on/off as I never turn it completely off.
    F
    mechanic69's Avatar
    Mar 2007
    374
    cheers
    Feb 2012
    58
    Thanks for the update peeps - Could you or anyone supply a link or instructions on how to fix this.. already sorted me B/T thanks to this forum so Im game for anything at the mo....
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Not got a link to hand, the cover underneath the steering column it held on by three bolts, 2 are underneath either side of the steering wheel, the third is behind the fuse cover, (open the drivers door its at the end of the dash)
    The cover will drop you have to pull it gently towards you from the drivers seat as it clipped in where it's splits from the top half, be careful of the obd connector it will still be attached, I get this cover of in less than 2 minutes now as I've done it so many times its is very easy . Once this is out the way the clutch switch is easy visible and easy to change.
    F
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Just to add, once the cover is off, get your head in the footwell and you will see a white switch with a rectangular plug in it where the clutch pedal sits at the top. This is the cruise control switch. Unplug the connector, twist and pull out.
    Nathan
    Jan 2012
    Kilmarnock, Scotland
    343
    Does anyone know if pressing the set button will alter a value when you log channel 066 with VCDS?
    My cruise isn;t working, but clutch switch, brake switch and the on/off part of the cruise switch are working. Only thing that didn;t seem to do anything was the SET button but I'm not sure if its supposed to or not
    Feb 2012
    58
    Quote Originally Posted by vroomtshh View Post
    Thanks for the information both of you. Thing is I forgot to ask DOH! What is the part number and roughly how much should I be paying? (I am lucky in that there is a main parts shop near me..
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Yes the values should change in measuring blocks when pressing the clutch, this indicates the switch is working, check the brake switch aswell.
    Clutch switch part number 7H0927189 about £15 from dealer ( someone on here payed £14 last November)
    F
    Jan 2012
    343
    Yes I have, but does the SET switch alter the value
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Are you doing this whilst not moving as cruise control will not work anyway so nothing will be measured, not sure if the values change when you are moving and the cruise button is pressed.
    F
  28. #27
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    hi mate, not sure if you sorted this yet as it is 3 weeks on?
    Using VCDS, go to steering module 16, measuring block 004, and then if you press the SET button, it should read. You should also be able to check the resume, speed up and speed down.
    Car does not need to be on, only ignition, all this is doing is checking the cruise stalk is functioning correctly.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  29. #28
    Jan 2012
    343
    Quote Originally Posted by Dannykn9 View Post
    cheers. I found that eventually and all is good. Still haven't fixed my cruise tho
  30. #29
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Have you changed your clutch switch mate. As already stated, although seems fine in VCDS, it can cure the problem. For the sake of £15, no harm can be done trying.
    It is well documented around the net that the B6/B7 are prone to faulty clutch switches, which Audi recognised this and therefor have a revised part number.
    5 min job to do. No mechanical experience needed.
  31. #30
    Jan 2012
    343
    Yes, and the brake switch, and the cruise control stalk, even though VCDS suggested they were all working
  32. #31
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Just a suggestion, the first time I swapped the clutch switch it didn't work and then found out if I kept pressing the set button and kept my foot slightly on the clutch it would work. If I lifted my foot of the switch it didn't. I found out if you don't install it right then it won't work.
    Nathan
  33. #32
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,608
    You could also bypass the clutch switch completely... cut the two wires and join them together, ignoring the clutch switch. Also means that you'll be allowed to change gear without knocking the Cruise off with the clutch.
  34. #33
    Jan 2012
    343
    The clutch switch isn't my problem unfortunately. I believe it's a speed sensor but I've given up trying to fix it for a while. I never use cruise anyway
  1. Retrofit cruise control problems help
    By flippin82 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 23:26
  2. If i didn't have bad luck I wouldn't have any luck!!!
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2011, 19:59
  3. Even more bad news , not having much luck
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2010, 17:59
  4. Please help cruise control problem 8P
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2009, 22:58
  5. any one have any experience EXPORTING a car?
    By sfource in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 03:18
