Badger5EM Tuning
Thread: Problems!!!!
    Sep 2007
    Chester
    48
    Problems!!!!
    Hi guys,
    Got a problem with my 2.0 Tdi 140 bhp, it has been suffering with the hesistation problem between 1400-2000 rpm. Now it has got worse when accelerating there is a cloud of black smoke until after 2000rpm every so often then the power is back!
    I've cleaned the air filter and the egr valve, but I noticed on the egr that the part which connects to the cooler pipe the valve doesnt open, its connected to a rod which is connected to a motor.....Any ideas?
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Anti shudder valve maybe?
    Get it scanned for fault codes.
    Sep 2007
    Chester
    48
    Yea its going in Friday, but I want an idea of what it could be before it goes in. The fact the valve part which connects to the cooler pipe doesnt operate.
    Nov 2011
    171
    The anti shudder valve is also referred to as the inlet manifold flap. It is supposed to open when you open the throttle allowing air into the vehicle and it is supposed to close when you turn off the car to prevent air getting in and ensure that the car shuts off properly.
    If this isn't opening at all then i imagine this will cause no end of problems.
    Sep 2007
    Chester
    48
    Well just scanned the car with my cheapy eBay software and this is what I got.......faults.jpg
  1. Transmission Problems
    By MisterD in forum General Technical / How To
    Last Post: 3rd February 2003, 13:23
  2. Ooo eck I've got a problem!
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2003, 13:12
  3. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
