JMB RetrofitsBadger5
    Nov 2011
    171
    Anti shudder valve problem
    Evening all
    I took my EGR valve apart yesterday to give it a good cleaning. Obviously in order to get the EGR out I had to remove the anti shudder valve but I just followed the guide instructions and left the anti shudder valve resting on the bottom of the engine so I didn't actually touch it.
    Since reassembling the car it now judders when I turn the car off. It isn't a really bad judder but it definitely judders and never did this before hand.
    Any ideas what could be causing this and how I can sort it ?
    i_786_i's Avatar
    Aug 2012
    57
    Have you also checked the gasket and pipe were correctly put back on?
    Nov 2011
    171
    No mate I haven't had chance to have a look at the gaskets but the pipe looks like its on correctly. I will have to take it apart again and check it all over. Do you think a gasket could cause this ?
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    I dont think a gasket could cause this, but if it not securing properly may allow air to escape/entering causing it to stutter?
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    You may want to try a ECU reset/Throttle Body Adjustment after you clean the throttle body.
    If you search either of these, there are many procedures on how it is performed.
  1. EGR and anti shudder valve removed and cleaned. Coated!!
    By Wats-on in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 21:44
  2. 1.9 tdi anti shudder valve
    By yendall24 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2010, 21:22
  3. forge splitR valve problems
    By AVUSSILVER in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2008, 11:58
  4. dump valve problem???
    By mrmattholmes in forum Tuning
    Last Post: 1st July 2008, 13:47
  5. A3 1.8T Dump Valve Problems
    By foolish3uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 21:23
