Volks AutosSky Insurance
Results 1 to 18 of 18
Thread: Parking sensors
    May 2011
    195
    Parking sensors
    Anyone know the part number for the rear parking sensors that would fit a 56 reg??
    kind regards
    lee
    May 2011
    195
    Anyone??
    Jun 2007
    Norfolk
    66
    I believe there is different ones dependant on model and position.
    I have been told the easiest way is to get under the car and remove the damaged one, then order that part number.
    I still have to do mine ....
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    7H0 919 275 D GRU (£80.95)
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Sep 2010
    Whitehaven, Cumbria
    56
    Just ring audi parts and give them your chassis number and theyl give you the correct part number and paint code, thats what i did then got some from german ebay. It worked out about half price from germany. Also the center sensors may be different from the corner sensors.
    26,774
    Yes but parts departments are weary of this these days & they dont tend to like giving out part numbers so much anymore as tbh I see there point, spend time for you then you go somewhere else.
    I've got 1 of these sensors available if you want, cheaper than audi.
    May 2011
    195
    How much matey, apart from vagcom is there any other way to see which ones at fault, apart from trial an error..
    Cheers again buddy
    Lee
    26,774
    Send me a Pm & we can sort it that way
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    VCDS is always the best and easiest way to diagnose the fault. A physical inspection wouldn't go a miss either. I've replaced a lot of sensors on a VW Passat as the chrome sensors at the front flake away.
    May 2011
    195
    Quote Originally Posted by jb0o View Post
    Do you have vagcom matey. If so any chance of plugging me in at all
    regards
    lee
    26,774
    Why not buy vcds
    May 2011
    195
    Why not buy vcds
    Lol you get me a VERY cheap version like?
    26,774
    Genuine vcds is cheap mate, vas is about £10k & doesnt even do somethings vcds can do, you pay for vas updates whereas vcds has been foc to date, support is foc, whereas vas is subcription based, no brainer, infact its a steal lol.
    May 2011
    195
    Sorry to resurrect an old thread but can someone tell me how to test the rear parking sensors using VCDS.
    Regards
    lee
    26,774
    Just login to pdc which is 76, then in measuring blocks there will be a block that shows the sensors & it reads distances of detection, walk in front of each & see if its changing, whats exactly wrong with them?
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,217
    Follow Brodster On Twitter Add Brodster on Facebook
    If its just to tell which sensor isnt working you dont need VCDS. Ignition on and put car in reverse. Lower yourself down to listen to each sensor in turn. You should be able to hear an audible clicking noise from each one. This is the signal being ommitted from the sensor. If you cant hear anything then that sensor is dodgy. A simple calibrated tap sometimes works aswell.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    May 2011
    195
    Cheers pal ill give that whirl.
    Thanks agagain I take it that the one that isnt clicking/vibrating is the knackered one
    May 2011
    195
    Just the usual long warning beep when you put it in reverse buddy. Must a sensor a problem as it happened before but sort of fixed itself lol
  1. Parking Sensors
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2005, 17:13
  2. Parking Sensors
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2004, 19:00
  3. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  4. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
  5. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
