Monster MotorsportBadger5
Results 1 to 8 of 8
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Angry Sudden loss of sound!?!?
    On the way back from AITP my HU reset its settings and now refuses to output any sound! Any of you guys had this problem or know what the cause could be?? Details in original thread:
    Sudden Loss of Sound & HU Settings changed???
    TIA
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    5.0 ?
    you have the RNS-E ?
    scan it for code
    mine did this i pulled the fuse DRIVERS SIDE cover
    left it over night and reffited fuse all good
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Not the RNS-E, just the Navigation 5.0. Single CD, dot-matrix display in red only, no SD card slots. Before the RNS-E was released (I think?)
    I did have the HU out yesterday to instal a subwoofer,but thats been working fine sice it went in... I'll give it another try in 10 mins or so and see what happens. If no luck leave the fuse out over night. Cheers Bez
    bez101's Avatar
    Jul 2008
    8,492
    yeah 5.0 i know the 1
    the fuse out has always worked for me
    but id recheck the wireing as you had it out
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Unfortuately my HU keys got nackered in the process because the release clips wouldn't come out. If it doesn't sort itself out I will order some more and check the wiring (which should be good as the connections were soldered and individually wrapped in electrical tape...
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    After waiting an hour or so, the problem seems to have disappeared...??
    Jun 2011
    245
    sound like you could have a pressure fault on the speaker wires which is causing the thermal cut out to kick in to save blowing your outputs ,i would check you have no trapped wires behind the head unit.
    dav
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Cheers Dav. If it ever does it again I'll have the HU out and check the wires
  1. sudden loss of power with 1.9 TDI engine
    By VAGMAN1 in forum Diesel forum
    Last Post: 21st September 2009, 15:46
  2. Sudden loss of power on 1.9 TDI engine
    By VAGMAN1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th May 2006, 19:36
  3. Sudden loss of power on a TDI engine
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2006, 00:11
  4. Sudden loss of power on TDI engine
    By VAGMAN1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th February 2006, 18:57
  5. Sudden loss of boost
    By AudiA4rulz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2004, 18:26
