AH FabricationsEM Tuning
Results 1 to 12 of 12
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Time for new wheels & tyres - but what offset?
    My 3.0TDi SE runs on 17 inch wheels with a ET45 offset. I have two sets of wheels, the OEM multi-spokes it came on (& which I'm not very keen on), see below:
    The other wheels are a set of RS6 reps I bought from Wheels Gateway a few years ago, although not for this car. They were for the B6 2.4SE I had before. The 3.0TDi is presently on the RS6 reps (see below)
    , and the tyres are all scrubbed out on the shoulders, so I thought this was the ideal time to go for some new wheels & tyres together.
    I'm going for 18s this time, and the style I fancy is the new-style RS4 wheel with 7 split spokes.
    The only thing I need to decide is what offset to go for. The choices seem to be ET35, ET42 and ET45. As I said, both of the 17-inch sets have an ET45 offset, but I notice the RS6 reps in particular are very close to the huge front brake calipers. There's only about 3mm clearance.
    I realise the 18 inch wheels should have more clearance anyway, but I don't know if the RS4 style spokes might be thicker, and could possible hit the brakes. Can anyone suggest what the best offset would be? Would ET35 stick out too far? Would ET45 clear the calipers?
    If it's relevant, I don't have any plans to lower the car at all. I like the ride height as it is, as my 50-year old bones need the extra wheel travel and bump absorbtion.
    Sorry for the tiny pics, I don't know why that happened, but if you click on them, they come up big.
    Hoping for some early responses, as I was planning to order them tomorrow morning
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    quattronly
    Jun 2011
    SW Scotland
    95
    My S-line Sp Ed came with those in ET42. If you can find someone local to you with one, you may be able to try their full-size spare. I would imagine they'll fit as there's a nominal 3mm more clearance than your originals. Tyre size on mine is 235/40 18, although I've tried 245s as well.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    I've got ET33 (12mm spacers on ET45 rims) and I think they sit really nicely. I also heard that ET45 won't clear the calipers on the 3.0tdi due to the fact they are the same size as the S4 (not 100% sure if this is true mind).
    However, if you buy ET45 wheels, you can always use spacers to adjust the resultant offset, but you can't make an ET35 wheel ET45. But then again if you're never going to put the wheels on another car maybe it isn't an issue.
    ET35 is generally regarded as the best offset for the B7 (from what I've seen/heard), and in my case I like the extra 2mm! If you're not lowering the car you can stick with 240 or 245 tyres also.
    Pic of mine on ET33 for reference (19" rims on 235/35/19 tyres): DSC_1182 [1280x768] | Flickr - Photo Sharing!
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    I've ordered them today, with offset ET42. With a bit of luck, they'll be shipped today, and on the car tomorrow.
    Pics to follow.
    quattronly
    Jun 2011
    SW Scotland
    95
    Quote Originally Posted by Jeeves View Post
    Just an update:
    Fitted the 245/40 R 18 on some ET45 wheels, and no issues whatsoever. In fact although the 40 profile remains constant, the extra 4mm of sidewall has made the car noticeably more comfortable. Could also be to do with having full tread, or the tyre costruction, but a worthwhile improvement. S line suspension wwas unmodified.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    198
    I was running ET35 8Jx18 on my B7 and it coulda done with spacers esp at the rear
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    Nov 2008
    389
    Jdp1962 - did you get these sorted? Interested to know where you purchased and pics?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Quote Originally Posted by phil_w View Post
    I did. I got a set of RS4 reps (ET42 8J x 18) with 235/40/18 Falken ZE912 tyres delivered for £750, from Wheels Gateway. I've used them before, and their service and prices are excellent.
    Only one pic of the car so far.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Jeff, what is the quality of there wheels like, do they last well. I have brand new 235 40 18 fitted to my rs6 alloys on my cab, I'm hoping I can put these tyres on the rs4 wheels.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    Quote Originally Posted by RMH1A4cab View Post
    This is the second set I've had from them. Obviously, I can't comment on durability yet, but the wheels seem fine. The finish is a bit rough and ready close-up, but other that, I've no complaints, not at that price. The 5-spoke S-Line reps I had from them a couple of years ago have lasted very well indeed. The only degradation in their condition was from me kerbing them.
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Re: Time for new wheels & tyres - but what offset?
    Quote Originally Posted by jdp1962 View Post
    :thumbup:
    Thanks, if I use my existing tires I can get a set for £350 which is a bargain, think I may have to get a set they are still the best looking wheel on an audi imo.
    F
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,314
    :thumbup:
    JFDI!
  1. Just ordered new wheels need tyre advice
    By Autograph Baz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 16:46
  2. Massively f**ked off and looking for new wheels...
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2008, 10:37
  3. A very big thanks to gordybaillie for new wheels
    By alnes in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2008, 10:43
  4. new wheels have arrived but no car....lol
    By Ballcrusher in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2008, 01:22
  5. Ideas for new wheels? (New RS4 maybe)
    By imported_trident21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2005, 17:01
