AH FabricationsEM Tuning
Results 1 to 9 of 9
    Oct 2011
    Cumbria
    89
    Really annoying squeaking noise!
    Hi, hopefully someone can help me as I am starting to pull my hair out.
    Basically when driving along over bumps, manholes, speed bumps etc I can hear a noise. It sounds more of a high pitch squeak than a rattle and is proving a bugger to try and work out where it's coming from.
    Really hard to pinpoint as a bump to any corner of the car seems to create the sound. I've had each wheel off whilst sitting trying to find any loose or wobbly parts to no avail. No sign of any exhaust or under panel sections that are loose.
    Is this a common thing on B7 s line avants? It doesn't seem to be a compression of the suspension issue as bumps that don't rattle or jolt the car don't cause the squeak.
    Please Help!
    A4 Avant tdi S-line
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,907
    Are your windows done up when you hear the squeek?
    Mine makes a slight squeek if one of the windows is slightly open, its the glass moving in the rubber.
    JSD 2.59
    Synergy-Solutions
    i_786_i's Avatar
    Aug 2012
    57
    Hi,
    If you have checked you suspension components anti-roll bar, wishbones, shocks etc try looking at the mounts they will tend to squeak if they damaged or leaking.
    Thanks,
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    I have the same issue if I drive along with my drivers window open.....giving up looking for the cause
    Jan 2012
    100
    i have the exact same problem and it is a pain in the back side.suspension seems ok but havent had a reall good look yet.car going in for a service next week so gawna ask audi to have a wee look.will post up if i get a result
    Oct 2011
    Cumbria
    89
    Well it's defo not window glass related. I'm certain it's at the back end of the car.
    Glad it's not just mine that does it, hopefully if it's fairly common then someone somewhere may know the answer.
    .............hmmm, just a thought that's come to me as I'm typing. Could it possibly be the exhaust hanger? Either a)softening in the summer heat or B) just being worn out and extra movement is letting the exhaust hit the heat guard?
    A4 Avant tdi S-line
    Noob
    Apr 2012
    North West London
    22
    Ive been having squeeking problems with my B7 Cabby. Was left side front and really bad when braking or turning at low speeds (such as 3 point turn). I could hear constant 'ticking' noise in line with the wheel revolution when the vehicle was in motion so wasnt all that surprised to find out that it was a wheel bearing. Got it replaced - end of squeek. Had to take it to a couple of mechanics as first ones came out in the car with me to listen to it and whilst they suspected it may be bearing, they sent me elsewhere for a second opinion! Second bloke said he was 90% sure before i told him to go ahead and replace.
    Any chance you are having the same problem and also finding it hard to clearly diagnose?
    Oct 2011
    Cumbria
    89
    Nooo its not a wheel bearing, that's a constant squeak/squeal.
    This is just a jerky bumpy moment split second squeak. Almost like something is loose and rattles over a bump, will probably jack her up again tomorrow and have another look around.
    A4 Avant tdi S-line
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    My b6 does the same like a tight bush creak squeak annoying !! Especially over speed bumps had mine checked new shockers springs bottom arm fitted still there !
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. Really annoying Squeaking noise
    By S3 Nattie in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2011, 23:03
  2. really annoying knocking rumble noise
    By mar1b0ro in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th December 2010, 23:39
  3. Radiator Fan Squeaking noise
    By JESSER S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2008, 12:46
  4. really annoying squeak
    By cjhill in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2006, 21:54
  5. squeaking noise at rear wheel
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2006, 17:44
