Thread: Diagnostic help
    Aug 2011
    17
    Diagnostic help
    Hi,
    I have a bit of an issue with my 2005 2.0tdi Avant.
    I have had power and uneven driving problems.
    I took the car to my independent dealer who changed the flywheel and clutch and also said that injector 4 was misfiring and not within specification.
    The fly wheel change did nothing really to change the problem.
    I then contacted Audi uk as some people here have said the injector is a known problem, they agreed to change them as a good will gesture but I had to take the car to an Audi dealer for verification.
    I have since taken it to 2 Audi dealers who have said there is no problem (surprisingly enough) and back to the independent dealer who are adamant the injector is at fault.
    I have a copy of VAG and a cable, does anyone know how I diagonse an injector fault so I can have a look myself before I call Audi uk again
    Aug 2010
    1,540
    look at the quantity comparisons for the injectors.
    if the figures are like;
    1) -0.08
    2) 0.78
    3) 0.02
    4) -2.87
    then yes youve got a problem with no.4 cylinder. but youd need to have a compression test done to make sure the ecu isnt trying to compensate for something (which its supposed to do). if all the cylinders are the same then by all means jump on the injector as a fault.
    but first swap the suspect no.4 injector with say no.3........ see if the -2.87ish figure moves with the swap before shelling out £400 on a new injector.
    i dont work with vagcom/vcds at work so cant advise on how to do that with it, but loads of people on here do.
    Aug 2011
    17
    great thanks, i'll have a look, if anyone has any VAG specific advice it would be much appreciated
    Aug 2011
    17
    Also i'm assuming the injector change is something I couldn't do myself
  1. Limp mode update after diagnostics.......help still required!
    By markfire in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th February 2014, 10:05
  2. Bluetooth obd diagnostic, help please
    By camscockle20vT in forum General Automotive Chat
    Last Post: 13th May 2012, 22:35
  3. Mayonaise on oil cap - diagnostic help please.
    By Rex16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2012, 20:49
  4. vag com diagnostic, help please
    By stumpy83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2012, 23:34
  5. Diagnostic help! (DTC's inside...)
    By cbass in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd January 2006, 19:25
