Volks AutosMonster Motorsport
Results 1 to 11 of 11
    Jul 2012
    192
    Smelly air vents after a service
    Hey guys,
    I got my car serviced and they changed some filters on the car.
    Since the service, I noticed that through the air vent there is a kind of horrible moist smell coming through.
    It is only noticeable when I have econ turned on and aircon is generally fine.
    I know there are many threads like this - but I rang the guy who serviced my car and he apologized for not letting me know about the smell but says I need to get it treated - his cost was £50 + vat
    does that sound reasonable?
    anything I can do myself?
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,007
    You get stale water in the ducting system and its this what smells. They will clean the ducting system out with an air bomb. You can do it yourself but you need to leave the windows open to vent it for a it afterwards. And then for about the next week afterwards when you drive it you will get a residue on the inside of your windows that looks like someone has rubbed their hair up the window, comes off easy enough, its just annoying.
    JSD 2.59
    Synergy-Solutions
    Jul 2012
    192
    does 50 quid plus vat sound reasonable?
    if they do it via the airbomb method will my windows still get residue on the inside of the windows for 7 days?
    marky67's Avatar
    Feb 2011
    Solihull
    56
    Yes
    A4 2.0 TDi 170 Quattro S Line
    Phantom Black
    Jul 2012
    192
    Quote Originally Posted by sidibear View Post
    If I did this myself is it quite difficult to do? what guide can I get online?
    Got limited knowledge on cars u see.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,696
    You can get a Comma air-con cleaning aerosol "bomb" from Halford for about £13. Follow the instructions to the letter and you should be fine. This reminds me, I should probably do mine.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,007
    Quote Originally Posted by psd99 View Post
    Yes, £50 is reasonable and yes you will still get the residue, it may clear quicker in your car, mine is only occasionally used. Once you have done it, open all the windows and vents and go for a drive, it may well clear it all out the vents. Mine was done in winter, so all the windows were shut when I used the car.
    JSD 2.59
    Synergy-Solutions
    D2NY G's Avatar
    Apr 2011
    1,042
    mine had a odd smell other week, not changed anything tho like filters ect, just dint have heaters on a few days and now its fine, weird lol
    Jul 2012
    192
    thanks gents,
    I must stress that the smell does not occur when air conditioning is turned on. I will recheck but I believe
    the problem is when I use ECON only.
    If I also press the button to bring air in from outside + econ I don't have a problem - the smell only from econ itself since my car got serviced.
    Will the halford comma aircon be useful here?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,696
    thanks gents,
    It should be. Most air con smells are the result of bacteria in the system, and the Comma bomb is an anti-bacterial cleaner.
    Jul 2012
    192
    The smell has died down far less than it was before
    the only thing i did was take out the filter and out it back in thanks everyone
  1. Air vents smelly particularly after turning air con off.
    By Graham89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2012, 09:33
  2. smelly air vents (8L)
    By knoxie in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2012, 23:03
  3. Air Con Re-Charge/Servicing in the Midlands?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2004, 19:03
  4. New A3 Air vents surrounds?
    By jasew in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2004, 19:01
  5. clicking noise from air vent???
    By xdam in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2004, 00:53
