JMB RetrofitsAH Fabrications
Results 1 to 15 of 15
    Jul 2012
    192
    Do Audi replace broken wipers on a routine service?
    hey guys do any of you know if audi will replace broken wipers when a car gets serviced?
    it looks like they do check it but not sure if they get replaced.
    thanks
    Jul 2012
    192
    what I meant was major service on the website it says this:
    Interim and major service inclusions:
    Both the interim and major services include the following (items in bold are not applicable for an interim service):
    • Electrics: All lights, warning lamps and horn function check
    • Vehicle exterior: Bodywork check for damage; windscreen; windscreen wash/wipe system; wiper blade condition and park position; headlight washer system; mirrors visual inspection/check heating if applicable; top up of screen wash; door locks and bonnet catch check & grease
    • Under bonnet: Oil and filter change, check auxiliary drive belts condition and tension, battery check, Coolant level check, clutch & hydraulics fluid level check, power steering fluid check, Air filter clean or replacement (if necessary), Fuel filter (diesel only) or Spark plugs (petrol only) replacement
    • Under vehicle: Front and rear brake pads/discs thickness and condition check; engine, gearbox, steering, suspension check; exhaust system visual check for leaks and damage; brake system: visual check for leaks and damage; under body visual check for damage, loose securing parts and for security; front and rear axle check (quattro models only)
    Price includes parts, oil, labour and VAT. Offer may be varied or withdrawn at any time.
    but I am not sure if that means they will replace broken wipers?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    What should happen, is that the garage should inspect the wiper blades as part of the service. If the inspection reveals that the a wiper blade needs replacing (either because it is worn or broken), then the garage should inform the owner, and obtain authority to change the blade. The cost of the new blade will be extra to any fixed price agreed for the service. I stress, that is what should happpen.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jul 2012
    192
    thanks
    so the wipers are damaged they made a big noise
    the man said he would charge me 30 quid plus vat for new ones
    or I could get these and fit em myself:
    http://www.amazon.co.uk/Onwards-Bosc.../dp/B005MPCRT0
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Do you seriously think Audi are going to give away as much as a set of wiper blades ?
    They will call you and advise they need changing and its up to you to make the decision. To be fair though, they charge you the same price that you will pay for them in their parts department.
    JSD 2.59
    Synergy-Solutions
    Jul 2012
    192
    ah okay that's a shame so they check 'em but don't change unless I agree to price
    lol shame
    I will get the ones from amazon then and fit 'em myself
    seems a reasonable price too
    Apr 2012
    N. Wales, LL22
    1,224
    all you want is the stamp, any extra work diy it
    i need a drop link on my civic, honda wanted £230 to fit, i've ordered the part online for £27
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Jul 2012
    192
    Quote Originally Posted by Ste_Nova View Post
    yer thanks I will order and replace em myself
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    Are they the right blades for a B7 A4? Was just looking on here:
    Audi A4 (incl. S4) Saloon 2004 to 2008 Twin Pack Wiper Blades
    The blades seem to be 22" ?
    Whereas the ones on Amazon seem to be these ones Bosch A298S Aerotwin Flat Windscreen Wiper Blades, Twin Pack 24 inch (600mm) & 20 inch (500mm) which are 24" and 20".
    BTW, no connection to wiperblades.co.uk, just a satisfied customer.
    Jul 2012
    192
    Quote Originally Posted by scotty76 View Post
    Hey thanks but I am a little bit unsure
    How will i know what the right ones are?
    Car is audi a4 2.0t fsi s line edition 2007
    Jul 2012
    192
    Ah my car is mk2 not a mk3
    So the ones you linked me must be the right ones and a case of easy installation
    Jul 2012
    192
    Just had a check on the car andmthe connector is the same as the wiperblades.co.uk wipers that u found
    but the wipers did not easily come,off what do i need to do to get them off?
    Jul 2012
    192
    SOrted i think good website
    I will try this tomorrow and order from Wiper Blades Ltd. | Suppliers of Quality Windscreen Wiper Blades.
    Them good site
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    Ah OK, makes sense. I've got a 2007 '57 plate 2.0 TFSi. Watch the video to see how the blades work...
    The reason you got me looking was because the blades on Amazon were a lot cheaper but obviously that's because they are the wrong ones.
    Jul 2012
    192
    Thanks for that
    I will try remove my ones tomorrow
    only,had the car a few weeks but it drives well very solid
    Thought id save some money lol
  1. Audi A3 rear wiper problem
    By Happyunited in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2008, 10:40
  2. Hello my Audi is broken
    By Uknowiama in forum The Welcome Section
    Last Post: 31st January 2008, 13:01
  3. Audi A4 B5 wiper, Door handle and flip key Q's
    By V6 family guy in forum General Technical / How To
    Last Post: 25th January 2008, 00:59
  4. Anyone replaced rear wiper motor?
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2005, 12:39
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
