Sky InsuranceChris Nott
    V6 Quatt's Avatar
    Feb 2008
    783
    Multifunction Steering Wheel
    I would like to replace my multifunctional steering Wheel on my Audi A4 B7 for another better condition multifuntional steering wheel Will my airbag fit straight on?? - or do you have to start matching up part numbers??
    The part number for the wheel id like to purchase is : 8K0 419 091 AK
    Help appriciated guys
    Torque the Torque
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    In theory mate, your airbag should fit that wheel, as 8K0 states that it is from an A4.
    But saying that, I have fitted cruise to many A4's and have noticed particuly on the cabs that some use an A3 wheel which have a different airbag fitment.
    I have a MFSW from an A4 that is in very good condition if interested mate, only thing is it has a couple of the slightest marks by the SDS button, but you could always swap out the buttons from you new one.
    Let me know if interested mate.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    27,097
    Best to remove your airbag & check the fitment underneath & into your wheel & compare with others including Danny's if they match, look carefully as some have 2 metal stud pillars to hold the airbag straight, this wasnt used on all cars, strangely, but is relevant.
  1. Retrofit MultiFunction Steering Wheel
    By wallacr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2007, 19:58
  2. B6 Multifunction Steering Wheel....
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th May 2007, 22:21
  3. Symphony 3 with multifunction steering wheel
    By Detector in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2007, 22:12
  4. Symphony 3 with multifunction steering wheel
    By Detector in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th May 2007, 10:28
  5. S-line - Multifunction Steering Wheel - Retro Fit
    By Badley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2007, 13:26
