Sky InsuranceJMB Retrofits
    Jul 2012
    Enfield
    21
    taking off brd manifold
    Does any one have or know of the sequence to take off the desiel manifold from the 170 's. Also how hard is it as all i want to do is fit the little vacume actuator Ie does it need to come off (looks like it does).
    Once i have done it ill be writting up the problems i have been having and hope this fixes them.
    Jun 2012
    7
    Alright mate, yes u do have to remove the manifold off the car for the vacuum actuator as to replace the actuator u need to turn it 180degrees for the shaft it is mounted on, it sounds complicated but is very obvious once u remove manifold. To remove take off air hose from intercooler to anti-judder valve,Then anti-judder valve, then remove EGR valve (also disconnect metal pipe from exhast to egr valve 2 bolts one can be a pain in arse if you remove bolt holding radiator black metal pipe to oil dipstick tube to give some movement enough to get sockets in once u start dismantling it's fairly obvious what I mean) and finally inlet mani. Afraid I'm not best at explaining but any questions just ask
  1. Would the plane take off?
    By imported_Nigma in forum General Chat
    Last Post: 9th January 2007, 19:31
  2. Would the plan take off
    By Geordie Mike in forum Rants & Raves
    Last Post: 20th December 2006, 17:27
  3. Taking off..
    By s3shabs in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2006, 12:25
  4. !.9 tdi just takes off
    By adidasandy in forum Diesel forum
    Last Post: 29th April 2006, 09:34
  5. Taking off somthin on a 5000S model
    By c_coffell64 in forum General Technical / How To
    Last Post: 18th June 2003, 00:23
