EM TuningSky Insurance
Results 1 to 10 of 10
Thread: A4 Cab CVT
    Jul 2012
    7
    A4 Cab CVT
    Hello all,
    Aplogies for the blatant newbie question!
    Looking to buy an A4 cab - Should I avoid the CVT box? I'm thinking the basic 1.8T with a manual box would be best?
    Will avoid Sport and S-Line as I like a nice sweet ride. Are there any particular pearls of wisdom that I should know about with the car.
    Where do the hoods start to go and all of that stuff?
    Any help gratefully received!
    Many thanks
    Jackson
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    I own a 2.0T S Line with the CVT gearbox, I would say it's a bit of a gamble as there smooth a silk when there running good but if they go wrong like mine (ECU with to pot which seem to be a common problem) it's going to cost an arm and leg to replace. I'd say stick to the manuals if you can find one with good mileage, also if your the remapping type you wont have the issues with limiting torque.
    Audi A4 2.0T Fsi S Line Multitronic
    Jul 2012
    7
    Thanks for the reply...
    How did the ECU fault manifest itself if you don't mind me asking?
    I think the 1.8 or 2.0 turbo with a manual box will be best -
    Thanks for your help
    CJ
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    Quote Originally Posted by Double Doom View Post
    CJ
    i think you should use the search tab and find out all you need to know
    bez101's Avatar
    Jul 2008
    8,491
    Lightbulb
    they drop in the boot
    Jul 2012
    7
    Wondering if this is priced right?
    http://www.usedcarexpert.co.uk/buy/a...90/id-6356255/
    Seems to be but it's hard to tell... I think it'll have to be a Multitronic...
    Any advice would be more than welcome - not hugely confident about this one.
    CJ
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    Problem started with what seemed to be a sudden drop in 'gears', doing 80 it thought that 1st gear would be better, red lined and the gear lights started flashing pulled over turned the engine off and on started no problem, did it every other week then happened more often soon the gear lights all the time (there's loads of vids on youtube mulitronic problems). Got it checked mainly because I was tired of buying new under pants everytime I had a motor was run. It is a big issue with all multitronic something to do with the position of the ECU, the 2007 will have the 7 plate clutch as does mine so there wont be an issue the that like some others. I say stick to the manuals unless your lazy like me. If it's a FWD it's Multi' (CVT - transmission) a 'Q' is going to be TIPTRONIC. (displacement better).
    Nagasaki's Avatar
    Aug 2012
    Henley on Thames
    24
    Am also a newbie, but for what it's worth we've had our A4 1.8t B7 CVT cab from new. (2006)
    REVO map to stage I 10,000 miles ago and stage II 1,500 miles ago.
    Not really driven in anger and as such no hint of problems with the box.
    Read a lot about CVT problems before modifying and remain convinced that later 7 clutch plate system is fine and a vast improvement over the previous system.
    Very smooth and comfy drive with instant oomph on demand.
    Jul 2012
    7
    Brilliant
    Good advice - I'll go for the later cars - or maybe a Q with the tip box.
    Really helpful,
    I'll post a link to the car I choose!
    Thanks again
    Doom
    Jul 2012
    7
    Having thought about it - and put this advice to use - it's got to be this.... (or something like it)
    http://www.usedcarexpert.co.uk/buy/a...09/id-8044210/
    Doom
  1. S4 Cab. Will AmD be doing the same package?
    By 18ME in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2003, 09:17
  2. Multitronic selection problem on 3.0 Cab
    By fatarnie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2003, 16:07
  3. 2002 A4 Cab roof trouble
    By gdcfc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th July 2003, 10:55
  4. Which chip for 1.8T with CVT tranny?
    By a4lover in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2003, 10:43
  5. A4 and CVT
    By Ken in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th March 2003, 21:49
