- Joined
- Jul 8, 2008
- Messages
- 9,420
- Reaction score
- 641
- Points
- 113
had a problem with the map sensor
fitted a new 1 car now starts and drives good.
but no boost ?
new codes
onday,23,July,2012,12:58:41:27402
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Address 01: Engine Labels: 03G-906-016-BLB.clb
Control Module Part Number: 03G 906 016 GN HW: 028 101 211 3
Component and/or Version: R4 2,0L EDC 0000SG 9618
Software Coding: 0000072
Work Shop Code: WSC 00783 210 91542
VCID: 75EA0B3F1CDA171
2 Faults Found:
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 11000100
Absolute Pres.: 1040.4 mbar
Absolute Pres.: 2182.8 mbar
16497 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Temperature: 133.2°C
Temperature: 87.3°C
Temperature: 74.7°C
will it be a bad map sensor ?
but no boost ?
new codes
2 Faults Found:
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Bin. Bits: 11000100
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.91 V
Temperature: 87.3°C
Temperature: 74.7°C
