JMB RetrofitsEM Tuning
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By CHEZ
Thread: Oh go on then, where's the CTS on my 2.0 TDi - BRD engine...
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    I've looked at all the different guides, checked elsawin and etka and searched my engine bay with a torch - still can't seem to locate my coolant emperature sensor!
    It's the 2.0 TDi 170 engine code BRD
    Any ideas guys...
    Mar 2013
    36
    Quote Originally Posted by Richardesty View Post
    Any ideas guys...
    anyone know if theres a photo showing location of coolnat temp sensor on 2.0 TDI 170 engine? Thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    Any ideas guys...
    hard to see its down the back just feel for ir
    say around 6" down very tight
    Mar 2013
    36
    Is that behind the engine - say, under the wiring plug for the injectors and glow plugs?
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    if like my blb it is located between the bulkhead and egr pipes about 10 inches down at the rear of block!
    Coolant temp sensor location on 2.0 tdi BLB engine code
    ricochet likes this.
    Mar 2013
    36
    Thanks very much for reply Chez, I'm all cleaned up now - will attack the beast again first thing tomorrow and post how I get on, thanks again
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,755
    it is a doddle mate once that pesky clip is out!
    follow the above advise and you cant go wrong!
    good luck and keep me posted!
    May 2012
    93
    just changed mine-what a pig! you are almost doing it blind. took about 30 minutes.
    Mar 2013
    36
    Any chance of posting a photo with arrow to CTS location please hubbo? Cheers
    May 2012
    93
    you cant actually see it to photograph! if you find the fuel temp sensor, follow the wire back to the loom, there will be another wire the same as the one going to the fuel temp sensor, follow that with your hand and you will come to the plug on the coolant temp sensor. remove the fuel filter to make it a bit easier. hope that helps. I will try post a pic of the general area later.
    Mar 2013
    36
    Thanks again Hubbo....errrr....which is the fuel temp' sensor!!
    May 2012
    93
    follow the fuel lines from the fuel filter-it is nearly dead centre at back top of engine, its the same type of sensor as the coolant one
    May 2012
    93
    this has cured my starting issues instantly-starts on the button-no rough starts now!
    Jan 2012
    112
    Quote Originally Posted by hubbo1 View Post
    I need to do this aswell as I keep getting a Coolant warning message on the DIS and changed the coolant bottle already, you haven't got a pic have you? I've got a 2.0 fsi. Did you have to remove anything to get to the CTS or did you just do it blind as I see mentioned above by somebody else?
  1. Where's the ECU located on 2.0 TDi?! (for remap!)
    By Petem95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2011, 00:12
  2. Where in the UK Can I Buy H&R Coilovers?
    By XXX_18T in forum General Chat
    Last Post: 14th November 2003, 10:29
  3. Where is the diverter valve on an A4
    By brookescourt in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2003, 16:30
  4. where have the forums gone?
    By sfource in forum General Chat
    Last Post: 21st June 2003, 19:16
  5. where will the creaks end? Bain of my life
    By dandy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2003, 08:25
