Chris NottJMB Retrofits
Results 1 to 9 of 9
Thread: help
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    help
    driveing down to south wales today on the M50
    car starts ****ing about loss of power jumping around
    turned off back on drove ok for a few miles
    did same again pulled over cut out.
    will start after a good cranking but revs bad and cuts out
    got recovered back to sunny sheffield
    and got these 2 codes
    16485
    16683
    iv read them up on rosstech wiki
    but could either 1 of the faults stop the car running ?
    bez101's Avatar
    Jul 2008
    8,520
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Control Module Part Number: 03G 906 016 GN HW: 028 101 211 3
    Component and/or Version: R4 2,0L EDC 0000SG 9618
    Software Coding: 0000072
    Work Shop Code: WSC 00783 210 91542
    VCID: 75EA0B3F1CDA171
    2 Faults Found:
    16485 - Mass Air Flow Sensor (G70)
    P0101 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 1323 /min
    Torque: 0.0 Nm
    Speed: 67.0 km/h
    Temperature: 54.0°C
    Mass Flow: 15.64 g/s
    (no units): 1.40
    Temperature: 90.9°C
    16683 - Boost Pressure Regulation
    P0299 - 000 - Control Range Not Reached
    Freeze Frame:
    RPM: 2856 /min
    Torque: 184.0 Nm
    Speed: 44.0 km/h
    Load: 77.6 %
    Voltage: 13.83 V
    Bin. Bits: 11000000
    Absolute Pres.: 2305.2 mbar
    Absolute Pres.: 1295.4 mbar
    Readiness: 1 1 0 0 0
    27,113
    Check air mass meter is plugged in ok as may have come unplugged & yes mass air can affect this as affectively its telling ecu air flow & adjust fuel accordingly.
    bez101's Avatar
    Jul 2008
    8,520
    1st thing i checked
    still the same when unplugged
    27,113
    Urm sounds like maf is buggered, can you check if its getting any flow registering in measuring blocks with vcds?
    bez101's Avatar
    Jul 2008
    8,520
    sorted was this lil fukker
    unplugged it car started and ran
    checked MAF was spot on.
    27,113
    Boost sensor, maybe not a good idea to run car without that working, as that effectively would not show boost levels correctly, maybe ok but I wouldnt want to risk incorrect boosting transmitted to the car systems.
    bez101's Avatar
    Jul 2008
    8,520
    im not running it
    was unplugged to find the fault
    left it in the garage till i get 1 in the morning.
    27,113
    Fair enough
  1. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
  2. I.T. help please!
    By MisterD in forum General Chat
    Last Post: 20th January 2003, 21:19
  3. Please help, my hard drive has disappeared !!
    By sidicks in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 17th January 2003, 15:43
  4. Help Wanted - Amusing slogan
    By Moresauce in forum General Chat
    Last Post: 13th January 2003, 01:18
  5. Banner AD include help????
    By Administrators in forum General Chat
    Last Post: 7th January 2003, 15:21
