Volks AutosAH Fabrications
    Jun 2010
    76
    CONCERT 3 radio fault.
    Hi, my sisters A4 is fitted with the concert 3 radio/cd (I think), the bigger than normal size radio. For the past few weeks its decided to turn off by itself and will come on again whenever it chooses! Is this a common problem/faulty unit/easy fix? I know the early concerts fitted to B5s were crap but cant find much info on the newer ones. Any ideas??
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,467
    If it's a B7 then that wll be a Concert II+ (the B8's have the Concert III).
    Worth checking with VCDS if the radio is showing any fault codes.
    The major problem with the Concert I in the B5 was the EEPROM that stored the volume settings dying through over-use (due to a silly firmware bug).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
  1. Concert Radio Code
    By astronought in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2005, 09:31
  2. Concert radio/cassette speed sensitive volume
    By imported_highlander1 in forum In-Car Entertainment
    Last Post: 4th January 2005, 14:16
  3. Concert Radio/CD and ice>Link Plus
    By dorgan in forum In-Car Entertainment
    Last Post: 31st December 2004, 16:40
  4. Concert radio
    By m4tyj in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2004, 16:29
  5. Concert Radio
    By nicks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 09:24
