Thread: Brake Pad help
    Jan 2011
    111
    Brake Pad help
    I am just in the process of fitting the new MTEC discs and pads in my '06 2.0tfsi Quattro. Having stripped the whole lot down it appears the pads are wrong. The outer pad on my set up is help in the caliper body by a sort of round spring clip which then is held by the big long clip. In the set frm MTEC it appears the outer pad just has a flat surface! the inner pads look to be the same though. Has there been a modifiaction or are these the wrong pads??
    Thanks. Phil
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Quote Originally Posted by PhilMill63 View Post
    Thanks. Phil
    Probably sent you the wrong pads!
    Do some searching online for the correct part numbers and then send them back
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Jan 2011
    111
    Wrong bloody discs too!! How the hell you tell the difference between 312 &321mm when its all assembled god knows. Now I'll have to pay to send them back. Not a happy boy
    Phil
  1. Brake pad help
    By MrBaker in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2011, 13:59
  2. Brake pad help.
    By Soupie69uk in forum General Chat
    Last Post: 4th September 2007, 13:45
  3. Brake Pad Help
    By chuckys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2006, 21:35
  4. Help on Brake pad replacement
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2006, 22:22
  5. Need help on brake pads
    By mazzy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2004, 10:10
