Volks AutosChris Nott
    Mar 2011
    19
    Resetting central locking ?.
    I did a search and I'm sure it's on here somewhere but anyway, I removed the battery to clear out the drain plugs and now the central locking isn't working from the fob, works on the key though so what's the correct way to reset so it works from the fob ?. Cheers.
    Nov 2011
    171
    I had to do this a few weeks ago. Not sure whether i did it the "correct" way but i put the key in the ignition, started the car up and then pressed the unlock button, followed by the lock button. It didn't make any noises but as soon as i removed the key and tried the key fob it worked straight away. Hope this helps
    Mar 2011
    19
    Thanks Oddie, I read something similar that said turn the key to first position and then hold the fob lock button for 30 seconds followed by the unlock button for 30 seconds, I'll give it a try unless anyone else knows different ?.
    Nov 2011
    171
    I didn't do that with mine pal, just started it up, pressed both buttons once and that was it, job done.
    Mar 2011
    19
    Just looked in the handbook, followed the instruction and the car locked on the remote, hopefully it's sorted.
  1. Remote central locking kit from Vagparts.com
    By cloggs in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2004, 17:58
  2. Remote central locking upgrade?
    By mareksio in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 18:06
  3. Central Locking Petrol Cap
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2004, 23:35
  4. advice on central locking and alarms
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th April 2004, 18:47
  5. HELP!!!!! Central locking not working.
    By howard in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2004, 08:57
