Volks AutosChris Nott
    Nov 2011
    Roof locked on one side & open on other
    I'm assuming this is going to involve a trip to the dealer but on the off-chance there's a simple solution thought I'd post here.
    I closed the roof automatically yesterday but was parked at a 45deg angle on a steep driveway - it appears there was enough flex in the chassis that the roof cover has locked on one side but the lock has not engaged on the other side leaving it ajar by 10mm. It won't unlock with the manual T Key so any suggestions - the rest of the mechanism still works it's just the cover won't unlcok/lock ?
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    311
    Quote Originally Posted by k3lvc View Post
    The assembly will be under some strain but you should be able to open it manually and close it correctly, unless it is bent.....
    Nov 2011
    Seems it's my lucky day/week - local dealer managed to exert more physical pressure than I was capable of/willing to and it's now free and working correctly again.
    Until next time ..................
  1. S3 self leveling headlights. One side not working.
    By A3 steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2010, 19:47
  2. Hot at one side... Cold at other
    By j033y in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2010, 22:17
  3. Boot release not working on one side...
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2010, 01:17
  4. S3 - pink headlight on one side - bulb or ballast??
    By GT130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2009, 14:31
  5. car higher on one side
    By Starry in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2007, 21:29
