Volks AutosAH Fabrications
Results 1 to 12 of 12
    Nov 2011
    171
    Mr Muscle Turbo Cleaning
    Hi All
    Some of you may have read that i have been experiencing a problem with my 2.0 TDI going into limp mode. Almost everyone seems to think that it is the turbo vanes sticking. If this is the case, can this be cured by using Mr Muscle oven cleaner as some people have done previously ?
    I have also read that you can use the innotec turbo cleaner. I am imagining this does the same thing as the Mr Muscle cleaner ?
    Has anyone ever tried the Mr Muscle trick on a B7 ?
    Apr 2010
    SWINDON / WILTSHIRE
    72
    I have done it on the EGR valve and manifold so don't see why it wouldn't work with the turbo.
    Nov 2011
    171
    Quote Originally Posted by ukdan View Post
    Cheers Dan. How hard was the EGR valve to do ?
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    I heard some using Mr Muscle while cleaning the EGR but I bought some Wynns carb cleaner instead and that worked brilliantly.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Apr 2010
    SWINDON / WILTSHIRE
    72
    Easy mate. Done it in a couple of hours (not including the Mr. Muscle bit).
    Do a search on Google ad there is some guides o it.
    Nov 2011
    171
    Cheers chaps. Can anybody else shed any light on the turbo cleaning then ?
    27,007
    Just remove the turbo & strip down & clean it out properly as it will happen again, I stripped down a few now & cleaned with a dremel circular wire brush attachment, looks like new, moves like new, but check for any play in the shaft.
    alpesh26's Avatar
    Mar 2011
    270
    I wrote a guide a while back for the Mr Muscle Turbo cleaning: DIY: Mr Muscle Turbo Clean did it on my 1.9TDi, I imagine the process is the same/similar on the 2.0TDi.
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Nov 2011
    171
    If i came down to your workshop would you be able to do this for me ?
    27,007
    Where are you based?
    Apr 2013
    Does anybody know if you can do a toyota surf 3.0 td ?
    madstaff's Avatar
    Apr 2012
    74
    As already said, nothing can beat a proper strip down and clean.
    Here's a turbo i did recently off an A3.
    Audi A4 Avant 2.0TDi S-Line Special Edition
  1. WOW !!!!! MR MUSCLE TURBO CLEANNING
    By marktdisport in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2014, 18:12
  2. DIY: Mr Muscle Turbo Clean
    By alpesh26 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th June 2012, 19:07
  3. Mr muscle TDi turbo clean - PD130
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2011, 19:51
  4. Turbo clean?
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2011, 13:38
  5. Turbo clean out!!!
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2010, 08:03
