EM TuningBadger5
Results 1 to 18 of 18
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    2007 2.0 TDi 170 - reluctant to start....ideas?
    My 2007 2.0 TDi 170 has 95,000 miles on the clock and has recently been some what lathargic when starting, and seems to be getting progressively worse.
    It has a full Audi service history, four new injectors, and was last serviced about 2 months ago. You may be aware from another thread that I've also recently cleaned my EGR valve.
    In my mind I ve been blaming the wet weather as its that bit worse after heavy rain.
    Sometimes takes three goes to get her to start, but when I do she runs fine!
    Any ideas?
    Rich
    Mar 2011
    North Wales
    210
    Mine has never started good ever since the injectors were changed, had it back to dealer, new egr but made no difference
    loves quattro
    Oct 2008
    Louth
    753
    Intriguing, although my last injector was replaced well over a year ago and the starting issues has only really been noted in the last couple of months....
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    My stepdad had this problem with his Leon. He changed the glowplugs and the car started immediately. Worth a try?
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    loves quattro
    Oct 2008
    Louth
    753
    Cheers Nathan, do you know roughly how much that cost?
    Mar 2011
    North Wales
    210
    Quote Originally Posted by Richardesty View Post
    Get them tested first
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I can't remember but it wasn't a huge amount, just need to get a tool to remove them. I'll try and remember to ask.
    Nathan
    Mar 2011
    North Wales
    210
    Quote Originally Posted by Wrath View Post
    I think they are about 25 quid each ( not from main dealer ) and I also think they are ceramic so not as straight forward a job as the old metal ones.
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    362
    Hello Richard,
    I would recommend to test the glow plugs, (connecting to battery and see how they light up and how fast.)
    I think they are about 8£ from TPS and as far as tooling goes, I removed the ones on my 140 tdi with a normal long socket.
    If it is not the glow plugs it could also be the engine coolant temperature sensor, have you got access to vagcom? It would be usefull to see what temperature it is showing under measuring blocks.
    madstaff's Avatar
    Apr 2012
    74
    Quote Originally Posted by Krumz View Post
    Hello Richard,
    I wouldn't advise testing them across a battery as i'm pretty sure you'll burn them out instantly as they're only designed to work at either 5 or 7 volts (cant remember which).
    Audi A4 Avant 2.0TDi S-Line Special Edition
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    changed mine starts perfect now
    i paid £7.67 from TPS inc vat as i know them
    didnt use no special tool as above long socket
    for the price they cost change them
    but could also be the CTS do you get any smoke when it starts ?
    Mar 2011
    North Wales
    210
    Bez - Are yours ceramic plugs ?
    bez101's Avatar
    Jul 2008
    8,525
    god knows cars a 2006 B7 170
    Mar 2011
    North Wales
    210
    Just had a dig around and if it is a BRD engine code then they are the more expensive ceramic plugs ( and a pain in the backside ) otherwise they are metal and quite straightforward
    mine are ceramic
    Feb 2011
    362
    Quote Originally Posted by daveevs View Post
    Hello Davees,
    Correct me if I am wrong but according to the attached wiring diagram they are 12 v (appreciate this is for a 140 2.0 Tdi)
    BPW Current flow diagram
    madstaff's Avatar
    Apr 2012
    74
    http://ngkntk.co.uk/wp-content/uploa...03/car-cat.pdf
    Page 111 of the actual catalogue shows the voltages 4.4, 5 and 7 volts.
    Aug 2011
    39
    Sluggish starting could also be caused by a battery that's on its way out...
    2007 A4 Avant 2.0pd 170 quattro S-line special edition
    1990 VW T3 Westfalia Atlantic 2.1 wasserboxer running lpg
    North East
    607
    Quote Originally Posted by SebRogers View Post
    I agree with Seb and suggest you get the battery tested first.
  1. Cold start problem - A3 2.0 TDi 170
    By matt_t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2014, 00:12
  2. 2007 2.0 TDI 170 DSG, very jerky 1st gear!
    By paultaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2011, 15:34
  3. Help ! 2007 b7 a4 tdi 170....engine will not turn over
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th August 2011, 19:54
  4. A3 tdi 170 sline sportback cold start (2006)
    By ian ditch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th September 2010, 09:01
  5. Cold Starting an A3 2.0 TDi 170.....
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2008, 19:37
