EM TuningBadger5
Results 1 to 7 of 7
    Dec 2003
    20
    2008 140 TDI Lumpy idle / slight wobble on idle. Help Please.
    Ok got a slight wobble on idle. Doesn't do this from cold but it becomes apparent when warm 90 as indicated on temp gauge.
    So far I have checked for fault codes but there aern't any.
    Flywheel and clutch only just done so it ain't that.
    Went to Audi and they suggested I get the injectors cleaned by them which has now been done and a new injector loom fitted but still the wobble persists.
    Injectors show a 5% tolerance difference and there are no misfires. In fact it drives perfectly well except that when first taking off when cold there is a slight splutter which doesn't manifest itself again.
    Just wondering where next to look for the fault. Engine mounts look ok with no leaks.
    Audi said when watching the wobble on idele that they've seen alot worse indicating it must be a common problem. Do I live with this.....is it that common as it seems it bit pants to me.....my father's 2 litre A6 on a 57 plate doesn't do the same.
    Any ideas chaps or cures??
    Dec 2003
    20
    Anyone???
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    To be honest mine does it, doesn't really bother me and I think they all do this to some degree.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jul 2011
    Teesside
    327
    Mine does it too. Asked the guy at the Audi specialist when it was in for a MoT and he said its nothing, he said it would be more of a hassle and cost to locate the problem. I live with it.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    New fuel filter cured mine for about 1000 miles then it came back again
    Can't say it bothers me that much to be honest, I just learnt to live with it, nice to know its not just mine though.
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    all my dervs have done it low and high miles
    Aug 2012
    just cured mine ,..was broken wire on fuel line were you would fit a chip ,.. mines now spot on ,..,
  1. car wobbles on idle TDI(possible injector problem!?)
    By MAD_Adamski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2012, 09:27
  2. Re Map required for my 2008 140 TDI. Suggestions plz
    By Ianb in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2012, 21:53
  3. 2.0 TFSI very slight wobble on idle - flywheel??
    By SunnyB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2012, 20:09
  4. 2008 Audi A3 140 Tdi Quote Please
    By remedy234 in forum Custom-Code UK
    Last Post: 3rd March 2012, 23:42
  5. a3 2.0 tdi slight misfire at idle ??
    By westu_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 11:28
