AH FabricationsJMB Retrofits
Results 1 to 14 of 14
    Lee Applin
    what vag com etc or whatever its called these days
    i need to buy a vag com or its called vcds or something like that now isnt it>? whats a good one to buy on ebay?
    Nov 2008
    389
    NHN on here sells genuine VCDS cables - give him a PM. Ebay ones not to be relied on.
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Lee Applin
    how much are they? just the cable? id want the software too and not the free version you used to get from ross tech
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    721
    Think they are the registered genuine ross-tech ones £250 last time i asked from memory
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Lee Applin
    feck me i just spat my coffee over my keyboard
    rizzini7's Avatar
    Jun 2011
    721
    lol, Thats the one you can do everything with tho
    rizzini7's Avatar
    Jun 2011
    721
    lol, yeah some work some dont. I picked one up off ebay that seems to work sometimes. You just have to make sure youre not connected to the net and accidently update it as it will overwrite the software and die. I have seen the odd genuine ones on ebay go cheap. Depends if you want to do coding or just wipe alarms etc... i assume
    Lee Applin
    any links by chance? seems to be lots on there dont want crappy one, but yesw use to read clear watch live data actual over desired if it does that, reset crash data etc
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by Lee Applin View Post
    The software you download from Ross-Tech is the FULL version - currently version 11.11.3
    Re eBay leads - it's a case of pot luck. Some work reliably but some don't, some support all the adaptation channels some don't, some support dual K-line some don't. If you can risk the money then an eBay one might work for you, but if you want something that will just work every time then get the genuine Ross-Tech one.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    rizzini7's Avatar
    Jun 2011
    721
    As petroldave said lol, sorry no link it was a one off seller.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,064
    Nov 2008
    389
    I think they'll be fine for just fault reading and initial diagnostics etc - Gendan also sell the genuine VCDS - however if you want to actually configure your car's settings then VCDS is the only way to go...
    27,038
    No links to illegal/counterfeit goods are allowed on the site.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,525
    Quote Originally Posted by phil_w View Post
    Absolutely, couldn't agree more.
  1. what vag-com do i need for a a3 1.8 turbo 1998
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2010, 17:42
  2. Engine Light came on.....Don't know what Vag Com Fault is about!
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th February 2010, 17:40
  3. What VAG COM for these cars
    By Aspen in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th March 2009, 09:35
  4. Replies: 2
    Last Post: 8th October 2008, 15:13
