AH FabricationsSky Insurance
Results 1 to 7 of 7
    Mar 2011
    112
    2.0TFSi Throttle Hesitation.
    Hi guys, not sure if this has been covered before, but my car appears to have a very slight hesitation when applying the throttle. Seems to be there in third and fourth gear, when applying throttle. Engine code is BUL, diverter valve is latest revision, new plugs, air filter and fuel filter at 43k, coilpack recall also done. Mileage is now at 53k. Any suggestions please.
    Apr 2012
    NTH Lincolnshire
    55
    Have you replaced or checked your diverter valve.
    They are a week link on a good engine.
    Keep meaning to take mine apart for a check over.
    Brad.
    craigcull's Avatar
    Oct 2011
    Leeds uk
    993
    Visit craigcull's Youtube Channel
    I have the same engine code, take it urz is 220bhp model? I've had nothing but trouble trying to loose flat spots. Only thing that solved it was a total upgrade of the diverter to the forge diverter/blow off valve. I've now lost every problem I've ever had. Also I changed the clutch switch as I was advised this could play a part. I've ha mine 16 month and only after the above have I seen the bk of the flat spots.
    Apr 2012
    NTH Lincolnshire
    55
    Craig, did you notice an improvement in the performance after fitting the Forge diverter.
    I love the car and handling, but I am a bit disappointed with the performance for a 200bhp car.
    Brad.
    craigcull's Avatar
    Oct 2011
    Leeds uk
    993
    Yes mate a noticeable difference, I was getting quite bored of poor performance ad poor fuel economy, but now I'm happy until k04 it.
    craigcull's Avatar
    Oct 2011
    Leeds uk
    993
    I would map mine as they are a tad under powered, but I want to change the clutch 1st. Afterall they do weigh over 1500kg.
    Mar 2011
    112
    Quote Originally Posted by Roadrunner146 View Post
    Brad.
    Yes as I said valve was changed last year for latest revision, but haven't checked it since as thought the latest was reliable. Is this not the case?
    Guy's thank for the replies so far.
  1. A3 1.8t agu part throttle hesitation
    By bengal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2010, 18:41
  2. Part-throttle hesitance/almost a stutttttter.
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2007, 08:08
  3. Audi's have sticky throttles?
    By sideshowbob123 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th December 2003, 10:10
  4. Hesitating S8
    By rterry in forum A8/S8 forum
    Last Post: 19th November 2003, 13:40
  5. S3 Hesitation (& DV)
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2003, 21:45
