Chris NottMonster Motorsport
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,873
    A4 2.0 TDI no eml light showing when ignition switched on none start
    Basically im posting for a friend whos car isnt starting as the eml light is not showing when he switches the ignition on to start then car he had it read and came up with engine ecu car starts and light comes on after flicking the ignition on and off a few times is this common or is it case of a sticking supply relay or is it internal to the engine ecu.
    Any help would be grateful.
    Brad
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Lee Applin
    Try a light tap on the ecu
    Aug 2010
    2,873
    Will tell him to give it ago next time it faults if it does show the light is it engine ecu ???
    Lee Applin
    it could be yes, not to panic though they are repairable for a couple hundred or so these days, bba reman are good for it, just dont use the one in poole dorset.
  1. A4 tdi 2.5 v6 : EML LIGHT & roof and window closure
    By Quattro-izy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2012, 09:02
  2. How to get the 'PSSSSSTTTT' With No EML Light
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2009, 10:42
  3. HID XENON Kits - A3 2.0 TDi (Next Generation Lighting)
    By fesss_84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2007, 22:26
  4. A3 TDI coil warning light!!!!
    By Daz A3 TDI 130 in forum Diesel forum
    Last Post: 1st August 2006, 03:09
  5. OIL & SERVICE LIGHT SHOWING ON A3 MILEAGE METER?
    By turbodan in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2006, 10:04
