Volks AutosEM Tuning
    Jun 2011
    20
    audi a4 bpw warning light
    hello please help have had emissions warning light and intermiitent dpf regen i have following fault code should i replace sensor g450 and where is it located many thanks jimbo 001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
    P0471 - 000 - -
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 2
    Fault Frequency: 2
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    (no units): 20.40
    (no units): 15.30
    Mass Flow: 5.69 g/s
    Temperature: 222.0°C
    Temperature: 16.2°C
    Sep 2008
    60
    Jun 2011
    20
    many thanks mate seems striaght forward enought,have done some reading and its mentioned the sensor needs adapting after fitting does this mean a forced regen thanks again
    Sep 2008
    60
    Well I certainly didn't do any kind of adaptation, all I did after fitting was clear the code and it's been fine to this day......no forced regen necessary in my case either I just resumed normal use of the car and it must have been through regeneration many times since.
    Jun 2011
    20
    All fitted mate took for a spin so far so good thanks for your help
  1. Audi A4 B8 Door Warning Light and Puddle Light retro fit
    By pns2007 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 10th April 2014, 13:53
  2. 'Engine oil pressure' warning light on 2004 Audi S4
    By Simon S4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2011, 22:04
  3. Oil Warning Light Problem, HELP 1st ever Audi
    By vinceremedy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2010, 15:20
  4. Audi A4 Avant dashboard warning lights - HELP!
    By vipergrm in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2009, 23:28
  5. AUDI A4 1998 Warning light problem? Help please!
    By jakeriddler in forum General Technical / How To
    Last Post: 22nd July 2008, 09:35
