170 diesel exhaust tips
L
Lee Applin
whilst my car was on the ramp i had a good look at exhaust as i dont like the pointy down exhaust on each side, the tip buts are just spot welded on so wouldnt be hard to chisel them off revealing the plain smaller straight pipe, only thing was i wasnt sure if i put some tips on the exhaust if they would be rubbing against the rear splitter thingy, i didnt look to see if i could bend the bracket to drop the system an inch if thats possible then i would imagine some nicer eye pleasing tips can be easily applied
anyone done this?
Yep straights go on a treat, id post a pic of mine but not allowed to yet?, pm me you email and i'll send it to you direct
Carl
no need to bend anything, if you do need to drop the back boxes down a touch. if you unbolt the rearmost hangers off the car you can put washers inbetween the hanger mounting and the car to space it down.
if going more than 2 washers you might need longer bolts tho.
