EM TuningChris Nott
Results 1 to 13 of 13
Thread: Wil they go on
    Feb 2012
    39
    Wil they go on
    Alright lads am I'm after a set of the rs4 b7 alloys 18", just wanted to know will the fit on me 2006 a4 .
    Thanx smithy
    Mar 2009
    589
    18inch rs4s will 19 inch wheels from an actual rs4 wont with out a lttle work !
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    Quote Originally Posted by Marrow View Post
    18" genuine RS4 wheels are also available - 19" was only standard in the UK (or with ceramic front brakes), with 18" as an option.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Mar 2009
    589
    Quote Originally Posted by PetrolDave:1612891
    They did an rs4 with 18s !?! I bet those wheels looked way too small in those pumped up arches !!!!!
    carl-1968's Avatar
    May 2012
    Nottingham
    450
    I got non oem's 19's with 255,35 tyres on and although its tight, they do fit, not put them on yet just test fitted 1 on the front and went for a drive, might put a thin 5-10mm spacer on just to be sure
    Feb 2012
    39
    Think am going 2 wait for a set of 18" for mine and do youse Lott think there is much difference between the 7.5 and the 8j
    Nov 2010
    114
    I think the 7.5j ones are off a3 do might be easier to come by, wouldn't have thought it would make much difference as long as the ET is similar
    quattronly
    Jun 2011
    SW Scotland
    95
    Quote Originally Posted by carl-1968 View Post
    What offset were they, and are you running standard suspension on your car - an S-line by any chance? I can access some titanium original RS4 style wheels but they're off a TT and the offset is 52 so I need to know how big the spacers should be. I've got away with 245/45 18 at this offset before, but an additional 5mm width inside and out is a tall order.
    Nov 2010
    114
    ^ normal offset for an S-line is about 43 with an 18x8 wheel and the tyre size is 235/40/18, i'm running merc GL wheels now and they're ET56 with 20mm spacers all round
    Genuine Audi 18" DTM/Special Edition 15 spoke wheels for sale with 3 good tyres, PM if interested!!!
    Feb 2012
    39
    Think am going 2 go for the 18" rs4s If a can find sum lol
    Feb 2012
    39
    Alright lads av seen a set of rs4 alloys of a a3 and the offset is 54 will these be alright for my a4
    Nov 2010
    114
    54 is quite high, mine are 56 and they needed spacers got 20mm all round and they still sit further in the arch than I want them to have a look at my thread if you want it's called 'finally got coilovers', even if you can get them straight in they'll b pretty tucked
    Lee Applin
    can i ask the genuine 18 inch rs4 wheels that are on the a4 s line special edition are they getting a good used price? or are they just basicly fake rs4 wheels?
  1. Recaros - are they already heated?
    By AlexStanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2005, 17:46
  2. RELAY! Where are they?
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2003, 16:11
  3. RELAY! Where are they?
    By RichA3Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th September 2003, 20:09
  4. Coil Packs - what do they do ?
    By audi_girl in forum General Technical / How To
    Last Post: 11th January 2003, 13:12
