Monster MotorsportChris Nott
    Apr 2012
    96
    Checking oil level!!!
    When does everybody check there oil level. On a cold engine or when it's warm???
    North East
    605
    Quote Originally Posted by Daz4311 View Post
    You do it when its warm and after giving the oil time to settle back into the sump.
    Nothing definitive on this but I run the engine to temperature ( i.e. after a run ) and then give it five minutes after switching the engine off before checking the level.
    You also need great eyes and a crystal ball if you are to make sense of the Audi dipstick, very poor design indeed and not user friendly.
    Paul B7
    Missed gear
    Jan 2006
    Kent
    386
    I always practice that you have to check the engine oil when the engine is cold as the oil needs to drain into the crankcase for an accurate reading.
    This is not true for modern engines though and you can read when the engine is stopped for over 10 minutes.
    I will still check in the morning when the engine is cold though!
    And yes, the B7 dipstick is tricky to read!
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    I do mine cold, same time for other fluids as well normally on Sunday mornings....ah id best go check then lol seeing as its not raining atm!
    Apr 2012
    N. Wales, LL22
    1,224
    audi once a week before moving to wash
    s2000 every time before its moved out of garage
    both always cold
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
  1. Engine temp for checking oil level?
    By Sussex A3 3.2 Quattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2007, 07:51
  2. Sounds daft- checking oil level??
    By sat1983 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2007, 23:32
  3. checking oil level - engine hot or cold?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2006, 11:53
  4. Best engine temp to check oil level?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2006, 14:08
  5. Checking Oil Levels / Consumption
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2006, 00:35
