Chris NottBadger5
Results 1 to 22 of 22
Thread: S3 injectors
    chrisa4quat's Avatar
    Sep 2004
    897
    S3 injectors
    Where can I get hold of some? Are these the best for the 2.0t upgrade?
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    944
    Ebay cheapest i have seen sets for 150-300 ,its a shame i didnt buy the ones for 150,i need a set now for ko4 conversion.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Feb 2011
    North Wales
    71
    Just bought a set off ebay for £98... Bargain!
    Sep 2004
    897
    How do I search? What s3 are they from?
    Feb 2011
    North Wales
    71
    This is the part number you need
    06F 906 036 F
    you can search ebay and google using that number.. i think you can get them cheaper off ebay.de
    Sep 2004
    897
    Quote Originally Posted by deian3387 View Post
    06F 906 036 F
    I'm guessing another remap will be in order after fitting?
    ANDYTQ's Avatar
    Oct 2003
    944
    They need to be the ones off the 2.0tsfi s3 not the early ones!
    ANDYTQ's Avatar
    Oct 2003
    944
    Yep correct no.
    ANDYTQ's Avatar
    Oct 2003
    944
    Yes a remap will be required after ko4 and injector fitment.
    Mar 2009
    589
    So no point fitting them without ko4 ?
    ANDYTQ's Avatar
    Oct 2003
    944
    You only need them with a ko4,otherwise just get a uprated fuel pump for st 2+.
    Sep 2004
    897
    What if I fitted just Injectors no ko4?
    Looking for 300bhp ish. Already have hpfp & decat
    Mar 2009
    589
    No gains by sounds of it mate !?! Waste of time snd money unless you get ko4
    ANDYTQ's Avatar
    Oct 2003
    944
    No point putting more fuel in if your not pumping extra air as well,otherwise it would just be mega rich.
    ANDYTQ's Avatar
    Oct 2003
    944
    Are you going ko4 then or ko4 hybrid?
    Sep 2004
    897
    Ko4 from 1.8t???
    Jun 2011
    138
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    ANDYTQ's Avatar
    Oct 2003
    944
    Quote Originally Posted by chrisa4quat View Post
    Ko4 from 1.8t???
    No ko4 from 2.0t s3,tts,golf edition 30,leon cupra.
    solaris's Avatar
    Slough, Berkshire
    404
    Ko4 from 1.8t???
    The K03 unit on the TFSi will out flow the k04 used on the early 1.8t.
    The flow rate of the current injectors are good enough for 300bhp if your going k04 then you'll need the S3 injectors, if your going for a bigger frame turbo then use RS4 injectors.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Sep 2004
    897
    I am after about 300 for now. Need to et a dyno. So far de cat, induction kit, hpfp internals, exhaust and a map. Just feels slow still. Friends say it aint but to me it is
    Mar 2009
    589
    Sounda like your just used to the power mate ! With your current mods you should be around 280ish so i very much doubt iys slow lol
    spider74's Avatar
    Feb 2012
    Scotland
    89
    Id reccomend the K04 upgrade, just do the Injectors and get a stock decent K04 from a 2.0tfsi TTS or S3. You only really need one custom pipe to make it work and mine mapped to just under 340ps and 470nm. Check out Solaris and his K04 Hybrid thread on both his and my builds. If you shop around you can get a K04 for about £600?
    Audi DTM edition, Sprint Blue, MRC remap, milltek, RS4 RARB.
  1. uprated sparks and injectors?
    By cyuen in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2004, 08:58
  2. Injectors
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2004, 18:38
  3. S3 injector flow rate/max HP
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2003, 11:43
  4. Injectors
    By AL_B in forum Diesel forum
    Last Post: 27th August 2003, 16:26
  5. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
