EM TuningAH Fabrications
    Feb 2012
    aylesbury
    6
    2008 a4 2.0tdi cab misfire
    hi guys
    any advice on what might be wrong with my car would be much appreciated
    to start at the beginning
    car = 2008 "58" audi a4 2.0 tdi cab engine code BPW less than 50k miles
    faults :-
    1, DPF light on dash, loss of power ( dpf removed and software adapted to allow for this)
    2, misfire ( there has been no good period between dpf issue and misfire)
    work done so far :-
    1, diagnostics with vag.com ( no fault codes )
    2, all 4 injectors removed and tested by specialist with no faults found ( replaced with new seals )
    3, live data showed no.4 injector to be considerably different to other 3
    4, injectors swapped no.1 & no.4, problem still at no.4
    5, wiring loom for injectors replaced
    6, compression test showed all equal and good
    7, egr valve removed and checked ( all working when compared to a new one )
    the injectors have been installed and set as per autodata
    please if i have missed something or you have any thoughts on the matter as its doing my head in
    Aug 2010
    1,540
    well from what youve said your problem obviously lies with cyl.4. the comparison reading being out. how out was it? what were the figures?
    and the compression test was all ok and even across all cylinders? even 40 psi lower in one cylinder will cause problems.
    you say youve swapped injector 4 and 1 around? and the "out" comparison figure stayed at cyl. 4?
    Feb 2012
    aylesbury
    6
    hi
    yes compression showed the same across all 4 cylinders
    the problem lies with cylinder 4 as which ever injector you put in no4 shows on live data being vastly different to other 3.
    i have removed vacuum pump from end of head to check fuel line, when its back together i'll get figures
    Aug 2010
    1,540
    the comparison figures are meerly the ecu trying to balance out variations in the power created in each cylinder. ie; say all cylinders were equally down on power the comparisons wouldnt look out. but one cylinder down on power youd see a minus figure for example...
    1) 0.9
    2) 1.4
    3) 1.1
    4) -2.8
    have you double checked the compressions? how are you checking them?
    should be roughly 80-100 psi on the first and 340/360psi after 8 cranks.
    if this checks out id go back to whoever mapped out the dpf for you, get them to look at it.
  1. 2008 2.0tdi a4 cab misfire
    By s3_stu_260 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 21st June 2012, 17:09
  2. 2008 A3 2.0tdi 140 - Remap in South Wales
    By W14FEN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2012, 19:26
  3. 2008 A6 2.0TDI rear light cluster problem
    By craigynett in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th August 2011, 08:58
  4. 3.0tdi Cab S-Line Quattro.To buy or not to buy???? Advise please
    By RacDave in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2011, 16:14
  5. Aftermarket HID Xenon Kit On 2008 A4 Cab
    By Benpage in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2009, 13:12
