    Jun 2012
    24
    2.0 tdi pd intermitent start issue
    hi all I am new to the foroum. I have just bought a 2005 a4 s line , I am very happy with the car apart from one small intermitent issue. the car will at times take slightly long to start, say three revoloutions and a slight cough before it fires up. it happens regardless of warm or cold and not all the time only at times. I have checked the battery (which is the orginal so 7 yrs old) for volts when starting sits at around 10v. checked earths etc, diesel supply for leaks. I have no fault codes on the car so I am now at a loss.
    I am wondering if it maybe is the nature of these pd engines? coming from a petrol which instantly starts maybe i am expecting too much? i am allowing all the dash lights out before starting..
    any ideas anyone???
    many thanks
    matthew
    Jun 2010
    44
    my battery just went without warning was a tad over 7 year old so if yours has been in 7 too it wouldnt hurt to relpace it. will save you an unexpected breakdown that may cost you a lot more to get sorted. i had no symptoms at all, then one day it was completly flat not even a turn left. you could top the old battery with de ionised water but that is only a temporary solution to a deadening battery. spend £100 or so on a decent sort and you'll have a car thats starting bang on. these cars wont use the glow plugs in this weather so should be noting to do with that. does it tend to start worse after a drive with lights/aircon/radio on ect? how does it start after a drive with none on theseon? have you has it scanned for fault codes?
  1. A4 Tdi AFN starting issues...
    By Final 3Green Land in forum Diesel forum
    Last Post: 1st September 2011, 17:05
  2. Audi A4 TDI Starting issues
    By Connor_scotland in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th February 2011, 13:11
  3. cold start issue tdi 130
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 16:16
  4. 1.9 tdi 130 starting issue
    By tnsl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2010, 19:05
  5. 2.5 tdi, a starting issue
    By samiam in forum Diesel forum
    Last Post: 19th November 2009, 09:30
