Fault code. whats the fix?
markfire
Essex.
Hi
Got me a VAG-Com thingy to check my car out.
Fault code 013128
Control Circuit for Controller for Turbo Charger 1 (j724) Electrical Malfuntion
Anyone had this fault and found a fix or solution.
regards
Mark
PS. Anyone needs their Audi diagnosed and are near Chigwell Essex i'll be happy to stick it on my new toy! small beer token applies to help me pay for it : )
Thanks mate............been there.
I guess its a case of working through all the different options until i find the culprit!!
regards
Mark
Ok thats good, as offering diag services with non genuine could have rather dyer consequences if causes problems :)
Thanks. Im only offering the use of, not claiming to know what I'm doing : )
Hello mark, I need to try and find a fault with my adaptive cruise control, a fault should show up on your machine which I desperately need. Is there a number I may contact you on to arrange a meet? Many thanks
dave
regards
Mark
You not thought about buying the kit for yourself Dave.
Well, the post by mark stated he had a system and was offering the use of it for a small fee, as he lives near me I considered it a no brainer to accept the offer.
Do you sell these systems by any chance?
Regardless if I sell these or not, my point to you would be the convenience factor, if its one of those faults that needs vcds constantly to work through the issue, then are you going to go back/forth everytime to have it scanned, acc uses a radar unit iirc, that isn't cheap, so you ideally need vcds with you whilst you eliminate the other possibles.
As a genuine sponsor of the site, I saw your issue & the car you had, made a suggestion, its up to you if you see worth in it :)
PS. Yes I do sell them :p
324
517
836
889
6
4K
