Monster MotorsportEM Tuning
Results 1 to 23 of 23
    Mar 2011
    North Wales
    201
    Question Glow Plug Light flashing
    Hi,
    Driving along doing about 75-80 in cruise control and suddenly the car loses power, the glow plug light flashes. I was able to pull over and switch off. After about a minute I restarted, no problem, the car went the rest of the journey ( about 15 miles ) without any further issues. Seems ok in cruise control also.
    Anyone have any ideas what the problem could have been as I'm a bit concerned about driving too far in the future.
    Many thanks
    Feb 2011
    North Wales
    70
    Quote Originally Posted by mm707 View Post
    Hi,
    Many thanks
    You need to get it scanned for codes mate.. could be a few different things
    Macdoon's Avatar
    Essex
    1,485
    Have you had the injectors/looms changed on recall.
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler.
    Mar 2011
    North Wales
    201
    Quote Originally Posted by Macdoon View Post
    Yes - about 10 months ago
    Macdoon's Avatar
    Essex
    1,485
    As above get it scanned, could be a number of things, and may be something really simple to fix.
    Mar 2011
    North Wales
    201
    Had it scanned and it showed this .....
    000665 - Boost Pressure Regulation: Control Range Not Reached P0299 - 006 - Short to Plus - Intermittent
    The bloke cleared the code and said it may have just been some muck from the egr, anyway he says it's best to get the revs right up and give it a bit of a thrash and see how it goes.
    Feb 2011
    Worcesterhsire in the UK
    13
    Thsi happened to me tyhe day before it went in for service and cambelt etc. Same code shown P0299 and my Indy suggested changing the turbo diverter valve, which he did.
    Two days after collecting the car it happened again tiwce in three days, so I will be getting it in again for him to check diagnostics. I don't know whether it is relevant but I had the injectors and loom replaced FOC under Audi goodwill last year.
    Will advise next course of shortly
    Mar 2011
    North Wales
    201
    Quote Originally Posted by daled View Post
    T I don't know whether it is relevant but I had the injectors and loom replaced FOC under Audi goodwill last year.
    Me too and it's never been 100% since , please let us know how you get on
    Mar 2011
    North Wales
    201
    Daled there's an interesting thread here
    2.0TDI limp mode Please Help!
    This guy has the same symptoms as me - it happened whilst accelerating slightly uphill in 6th. If yours is the same it's worth a read.
    Jun 2011
    NW London
    141
    hello mm707,
    this might be completely irrelivent, but i used to use crappy supermarket petrol and this happened to me twice, up a slight hill on motorway doing similar speed. coil light on and limp mode, switch of and on and back to normal. Both times no fault was logged. I have now switched to either bp or shell and it hasnt happened since, 7 months and about 7k.
    Apart from that i also have a hessitation after injector inspection by whetstone audi.
    cheers
    matt
    Feb 2011
    North Wales
    70
    Iv'e had this once on a car at work and it was a faulty MAP sensor (turbo pressure sensor)
    Fitted a new one and the car was sorted
    Aug 2010
    1,540
    what engine code is this?
    Mar 2011
    North Wales
    201
    Quote Originally Posted by murran View Post
    it's a BRD engine
    thanks
    Aug 2010
    1,540
    the fault code you posted up is to do with unexpected low boost pressure for a driving condition.
    given the engine code id be removing the egr valve and checking the flap is secure and able to rotate smoothly.
    Mar 2011
    North Wales
    201
    Question
    Hi Murran, thanks for this. It had a new EGR about 18 months ago and has only done about 6k since, would you still check it ?
    Mar 2011
    North Wales
    201
    Seems a bit sluggish too but only when accelerating at slow speed, when the revs are high it flies along no problem
    Mar 2011
    North Wales
    201
    New vacuum unit on the inlet manifold has cured this. Fairly easy job and only about £10 for the part. Opened the old one and the diaphragm inside had a hole in it.
    No more hesitation when accelerating either.
    Aug 2010
    1,540
    which vacuum unit?
    Mar 2011
    North Wales
    201
    which vacuum unit?
    Part number S03G129061C , at front of engine, near top.
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Been having the same issues with ours for a couple of years and haven't been able to resolve it yet. Had the injectors and loom done on the recall but still have this issue. I need to get the EGR off for a clean (although it looks like a new part I can't be sure when it was changed). I will also have a look at the vacume unit.
    Let us know how you get on.
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Mar 2011
    North Wales
    201
    'Let us know how you get on.'
    This part fixed the problems I was having with hesitation and the underboost. To fit it you need to take off the egr and inlet manifold which was a lot easier than I thought it would be. My egr wasn't too bad as it was only 18 months old but I cleaned quite a lot of crud from the inlet manifold flaps etc. If you do it just be aware that there is a bolt holding the manifold on in the air intake which is usually covered in muck and not easy to see though easy to remove when you clean it up.
    vacuum unit is about £10 and if you replace all the gasgets it takes it up to just short of £20
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Oops sorry mate. That will teach me not to skim read threads! Glad you found a fix and this is something ill mention to my mechanic next time it's in the shop!
    Sep 2012
    Just got home after a half hour drive and my glow plug warning light has started flashing. The car seems to running ok with no power loss. Have stopped and started it a few times but the light keeps flashing, even with the engine off/ignition on. I had the car serviced by audi back in november, and it had all the injectors replaced under an audi recall. Having read some of the posts above im now wondering if having that done has caused a problem? Have also checked my brake light bulbs and there all working too. Is the car safe to drive for now or will it do any harm?
  1. Glow plug light flashing
    By Cruz in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2013, 10:50
  2. Glow Plug light flashes
    By snowball1969 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th January 2011, 09:18
  3. Replies: 2
    Last Post: 25th November 2010, 16:00
  4. glow plugs light flashing
    By oilyaudi in forum Diesel forum
    Last Post: 11th October 2009, 12:43
  5. ESP Light on solid /Glow Plug light flashing??
    By vincenzo_2k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2008, 21:23
