AH FabricationsEM Tuning
Results 1 to 1 of 1
    Molnboman's Avatar
    Squeek from drivers side mostly after braking.
    Hej
    Can anyone give me their thoughts on this. I noticed high pitched squeek changing at speed after around 15 minutes driving and when mostly after applying the brakes. Had a checked out at the stealers and the identified that the rotors were gubbed. Chenged them with fresh mintex pads and discs, cleaned the crap off the calipers really well and applied high quality pad grease too and thought that had cured it. However, it's still there although this time it almost a different squeek but from the same side. Visulaly checked the cv and other joints and they all look good, and even tried to push back the rotor backing plate which is solid anyway....Am I looking at a faulty bearing?....I have had bearings go before on other cars and this does not sound like one. Also it doesn't happen over bumps and I can't feel it through the sterring wheel, so am thinking it a brake / caliper / bearing. The car is driving and handling well......which is all the more annoying. Anyone have any ideas?
    Thanks in advance,
    Allan
  1. Rattling noise from front driver side
    By sanj_c in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 23:33
  2. Driver side brake light
    By donerkebab in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2010, 09:01
  3. Rotational Rattling Noise From Drivers Side Front Wheel...Please help!
    By Nickpap in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2010, 21:04
  4. strange whirring noise coming from drivers side front wheel
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 23:37
  5. S3 rattling noise from passengers side
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2004, 21:16
