JMB RetrofitsBadger5
    11
    Air con problems. update/ hdcs
    so i have no cold air coming out of air con. had it regassed still no cold air, downloaded vcds lite scanned the hvac module ( which i think is for the air con / climate control ) comes up no faults. dont know what else to do HELP PLEASE. cant afford to take it to dealers, have three very expensive daughters.
    Molnboman's Avatar
    Do you have air coming through at all....just not cold?.....Did you have your condensor checked out...is that ok?
    A
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Alternatively your compressor is shot. Not sure if that would come up with vcds errors but it's an expensive part unless you can get one from a scrappy. Thing is, you'll need to get it regassed if it is the compressor.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jun 2011
    245
    is the econ light on the climate controls lit up and will not switch off when pressed if so its the sensor mounted on the side of the aircon radiator behind the front bumper, had this on my 2003 a4 cabriolet ,cost around £35 quid from audi if i remember correctly and is just unscrew old and screw in new unit .
    cheers dav
  1. Air Con Problems
    By WAL4D in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 21:39
  2. Air Con Problem: Slothlike coldness
    By hyperaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2006, 08:44
  3. Air Con Problem
    By Quattro_Lew in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2006, 21:54
  4. Air Con Problems A3 1.8 T Sport
    By jester104 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2006, 14:15
  5. Air Con-Problem
    By Jason in forum General Technical / How To
    Last Post: 22nd May 2006, 13:41
