Monster MotorsportEM Tuning
    May 2012
    Cheshunt , Herts
    22
    Audi A4 Cabriolet roof problem -- Implausible Signal ---Help with signal codes please
    I have had a major headache with this, i have replaced all the roof tray and components that are in the boot as i broke that. I have had a full VAGCOM rest done and when it read the code sequence for the roof open and shut it came up with this
    OPEN
    Address 26: Auto Roof (8H0 959 255 )
    19:19:31 Group 001: Convertible Top Status (Actual)
    Not Oper. Convertible Top Control Switch
    00100001 Switches && Positions I
    10 1010 Switches && Positions II
    30.0 Top Frame Position (G356)
    AND ALSO
    CLOSED
    19:13:35 Group 001: Convertible Top Status (Actual)
    00011010 Switches && Positions I
    138.0 Top Frame Position (G356)
    Address 26: Auto Roof Labels:
    Control Module Part Number: 8H0 959 255
    Component and/or Version: VSG B6 CABRIO 6286
    Software Coding:
    Work Shop Code: WSC 00672 785 00200
    VCID: F3E0C3AC91AE891
    1 Fault Found:
    02000 - Switch Position
    008 - Implausible Signal
    Now apparantly the code sequence for the first few digits on the SWITCHES & POSITIONS 1 are wrong
    The first set should read
    00101001 but reads 00100001 (open)
    The second reads
    11011010 but reads 00011010 (closed)
    Please can someone tell me which microswitch or switches need changing if that is the case, many thanks in advance, Nick
    Jun 2007
    Norfolk
    66
    I replaced the G356 switch on my cab.
    It is a potentiometer locates in the main pivot point of the roof to body.
    They have brought out a revised switch since mine was made
    Part number:
    Top Frame Position Sensor 8HO 959 613 A
    its about £60 expensive for a switch, but i don't get any fault codes now.
    This was my faults:
    2 Faults Found:
    008 - Implausible Signal - Intermittent
    01986 - Convertible Top Frame Position Sensor (G356)
  1. help with fault code please p1847 18255 A3 2.0 TDI 140 BHP REG JULY 2005
    By adiehorrocks in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th August 2011, 21:20
  2. Help with fault codes please - Update : new problem found + video
    By J_V_DUB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2011, 09:26
  3. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  4. Help with this code please...
    By terrymcg in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd July 2007, 17:28
  5. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
