JMB RetrofitsBadger5
Results 1 to 17 of 17
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    My Lack Of Offset/ET Knowledge!
    I have been on a quest to find myself a good used set of 19' alloy wheels for my Audi A4 B7 S-Line Saloon, to find myself stuck when they start talking ET's and Offsets. I did some reading and know they basics, the lower the offset the more it 'sticks out' toward the arch and the higher the offset, the more it 'sticks in' to the arches - but I don't really know the range in which I have to play for my A4 without causing any rubbing or fouling of the calipers. I've tried searching but to no avail..
    Can anyone help?!
    I am looking at some Audi/BBS Speedlines in 19X8.5J - PCD 5x112 - ET48 - Center Bore 57.1, and the supplied tyres which will need replacing are 255/35/19.
    Thanks all!
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    I did a little more searching on the international forums and from what I gather, the OEM S-Line's have a diameter of 18 inches with a width of 8 inches, and the offset being ET43 (43mm).
    The offset range can be anything between ET35 and ET45 depending on the size and width of the rims.
    So with this in mind, what kind of spacers would I need to get for these alloys?
    Check Out My Blog! Ryan-LDN.Blogspot.co.uk
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    That offet will work.
    You may need spacers if you want a more flush look
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    537
    What your buying will be fine, buy them and fit them, if there is a masive gap, get some spacers, I'm running 19x8 BBS with et50 on 215/35/19 tires and have 15mm spacers in and my car is decked to the floor.......no rubbing and looks sweet
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    ONLY buy hubcentric spacers. Don't buy the cheap universal ones from ebay for £10.
    I've just recieved my spacers in the post today and I was in your situation at the beginning of the week. Original alloys offset was ET43. New ones were ET45 (2mm less 'sticky-out' than OEM). As I wanted them to sit flush with the arches and I had about a 10mm gap with OEM I bough 12mm spacers. Which with the new wheels will give an effective ET33.
    It varies depending on how you want the wheels to sit as to what spacers YOU need. But each 1mm added to a spacer takes away 1 from your resultant ET value. I will post picks when I get my wheels, springs, brakes & spacers fitted on 25th...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Apr 2009
    Coventry
    2,214
    This might help
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    I just wish all audi wheels were the same offset
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    JJMurphy21187, Where did you end up getting the hubcentric spacers & bolts from? I've seen a few on eBay for around £45+, specifically the 10mm ones.
    So on the alloys I intend to get which are a ET48, those spacers will bring it down to a ET38?
    It's hard to imagine such small measurements make such a difference!
    Jun 2011
    245
    i am running an s line and have just dropped it 45mm fitted 19" alloys with 235/35/19s alloys are et45 but didn't fill the arches so fitted 15mm hubcentric spacers giving an et of 30 and they fill the arches nicely ,no issues with rubbing or catching as yet .
    if you were to buy the alloys with et 48 they are around 12mm wider than standard so will be 6mm wider either side of the centre line anyway which is near enough the standard wheel position ,but personally i would run at least 15mm spacers on those .
    lowered 45mm on eibach sportslines ,19's with et 45
    with same set up and 15mm hubcentric spacers fitted
    cheers dav
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    Cheers for the info Dav, and nice looking alloys! I was looking around for the hubcentric spacers and found loads of companies selling them. Did you go for a specific brand? I read the aluminium ones are the best somewhere on this forum..
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    Just a quick one, I found this website Audi guide for correct wheel fitment, PCD, and offset of your car | Alloy Wheel Fitment which shows the available offsets that would fit all Audi's, as well as other car manufacturers! Handy site!
    Jun 2011
    245
    these are the ones i bought , excellent service and quality
    JJC Audi 15mm Wheel Spacer Kit 5x100 and 5x112 Hubcentric A3 A4 A6 A8 S8 S6 | eBay
    only thing i found was they are very tight on the hub as the spacer tappers off but i wound them on with a nut gun before fitting the wheel and they run true and straight no vibration or wheel wobble.
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Quote Originally Posted by RYN-LDN View Post
    I got mine from Mark @ BM Autosport, same place as my alloys. Great customer service. They were 12mm & £75 a pair including extended bolts, which you'll need which ever spacers you buy, so factor in that cost when comparing prices... I also got some locking bolts separately from ebay for about £20. I believe they were all TPI branded. Nice anodised black finish so they'll match my black coated discs when they come too. In the end I decided to get them from Mark because he seems to know his stuff and I wasn't 100% on which fitment I needed.
    I'm really tempted to get 245/35/19 tyres and avoid the stretched look... would be great if someone could comment on rubbing issues!?
    Mr Crown
    Jun 2012
    Essex
    Am I correct in thinking that an offset of 30 with 19" wheels, lowered a small quantity on coilovers, would be pretty close to flush? I'd like flush, but not pull me over. (B7 3.0 Quattro)
    RYN-LDN's Avatar
    Jun 2012
    London
    35
    After collecting the Speedline alloys, cleaning, sealing and buffing them, I went my local tyre shop today and they rebalanced the alloys and as they were fitting them, the tyre was in contact with the suspension arm! Ergh! What a fail!
    Now I need some hubcentric spacers and I shall once again begin my search on good ol' eBay. Question is, how much clearance do I need?! would 10mm cut it or should I get 15mm/20mm?
    Mar 2013
    Alloys
    Hi
    are they 19"x8.5j
    regards
    jas
    Mar 2013
    Sorry that was for davsa4
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,663
    Holy thread resurrection, Batman!
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
  1. pulling my hair out through lack of knowledge
    By brickwize in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 20th January 2012, 20:31
  2. Lack of Knowledge
    By ttandka in forum A8/S8 forum
    Last Post: 10th February 2004, 08:32
  3. Offset confusion
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2003, 12:32
  4. offsets for alloys...
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2003, 19:59
  5. S3 Avus offset
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2003, 22:50
