Chris NottVolks Autos
Results 1 to 17 of 17
    May 2012
    87
    oil pump replacement
    hi, is there any info on here about how to replace the chain driven pump with the geard pump?
    thanks
    madstaff's Avatar
    Apr 2012
    73
    Make yourself a cuppa and have a read of this :-
    http://pics.tdiclub.com/data/3419/BHW_Balance_Shaft_Module_Replacement.pdf
    Audi A4 Avant 2.0TDi S-Line Special Edition
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    311
    Quote Originally Posted by hubbo1 View Post
    thanks
    Are you having trouble with the Oil Pump ? I know Sanburn can do away with the whole silly balance shaft assembly and replace it with the reliable oil pump setup out of the 1.9 TDI engines. Give then a call 02476637376 and speak to Wayne
    May 2012
    87
    hi
    have got gear driven unit just need some tech advice on removal
    thanks
    May 2012
    87
    thanks
    Feb 2011
    311
    hi
    thanks
    Hi Hubbo,
    I have access to Elsa which will give a step by step guide on replacing the drive arrangement and pump, see sample below for my engine, send me your year, model, engine code and gearbox type and I will post the relevant sections on here for you
    https://dl.dropbox.com/u/38150502/A4...20assembly.pdf
    May 2012
    87
    hi
    2005-a4-s-line 2.0 tdi-blb engine-cvt multitronic.
    thanks very much-also is there any info for cam belt change? as i imagine this will need to be changed?
    many thanks
    andy
    madstaff's Avatar
    Apr 2012
    73
    Quote Originally Posted by Krumz View Post
    Hi Hubbo,
    Sorry to barge in on this, but would you have the relevant information on Elsa on how to replace the injectors on a 2007 A4 TDI, fitted with a 16V PD TDI, engine code BRD.
    A step by step guide would be a help, and the relevant torque settings would be fantastic.
    Thanks.
    Feb 2011
    311
    hi
    many thanks
    andy
    Hi Andy,
    Apologies for the delay mate, attached procedures below for:
    Removing and Installing Oil Pump Chain Driven
    Removing and Installing Oil Pump Gear Driven
    Cambelt Replacement
    https://dl.dropbox.com/u/38150502/Au...eplacement.zip
    Hope this helps
    Feb 2011
    311
    Quote Originally Posted by daveevs View Post
    Thanks.
    Here you go mate
    https://dl.dropbox.com/u/38150502/Au...D%20Engine.zip
    Lee Applin
    Thanks.
    have you not csalled the main dealers to check to see if its due a recall on them? my car was done a few months back all for free
    madstaff's Avatar
    Apr 2012
    73
    Thanks for that.
    Quote Originally Posted by Lee Applin View Post
    Already had all 4 done in its life - had 1 done, then another 1 done then 2 through recall i believe, all before i owned it. Just waiting for Audi to inform me if its had all 4 done, when and where.
    Been suffering starting problems when my car has not been used for a couple of days which i thought could possibly be fuel pressure related, hence the (hopefully not) need for the guide to replace the injector seals.
    May 2012
    87
    thats great krumz
    many thanks
    Lee Applin
    Thanks for that.
    to me that points more towards air being drawn in somewere, ie leaky fuel filter / fuel pipe fitting on the low pressure side
    madstaff's Avatar
    Apr 2012
    73
    Changed the fuel filter the other day, fitted a genuine VAG filter and put the supplied new 'o' rings on the thermostatic t piece - which did feel as though it was definately a good fit when pushed in.
    Fingers crossed.
    Feb 2013
    West Yorkshire
    59
    I am going to have the gear driven oil pump replaced to 1.9 version any else had it done any issues ?
    Feb 2011
    311
    Quote Originally Posted by Bald man View Post
    I believe you need to change the sprocket, chain, chain guide and pump. Also think you need to plug the oil supply holes in the block to the balance shaft assembly.
  1. Replacement oil pump
    By Andy123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2011, 16:16
  2. Audi S3 replace oil pump
    By Agric04 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2011, 08:10
  3. Is it worth me replacing the oil pump strainer?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 20:30
  4. Replacing oil pump!
    By Lee Goodall in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th August 2008, 19:31
  5. Oil Pump 5 cylinder Engine
    By imported_Vinnie in forum Classic Audi Forum
    Last Post: 26th February 2005, 18:33
