Results 1 to 21 of 21
    Jun 2012
    13
    Is there an Ipod connection on the 2006 Audi A4?
    Hi guys,
    first post - I've just bought a 2006 Audi A4 2.0T FSI S line Special Edition.
    What a motor!
    I could fill the rest of this post with how impressive a car it is, but one thing I am trying to do is connect an ipod to the sound system.
    Its a Audi Syphony 6 CD changer.
    In my previous car there was an ipod connection in the glove box but I can't find such a connection in this car. There is nothing in the glove box other than some small empty holes at the back. Does this mean the whole radio/cd unit needs to be removed and an after-sales ipod convertor/connector added?
    I'd be interested to hear from anyone with the same car and if there is a ipod connection somewhere hidden?
    Camus.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,276
    ​Hi, welcome to ASN. Any pics of the car? Hope you enjoy the forum. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Jun 2012
    13
    Hi Sandra,
    I will upload some tonight - at work now.
    Camus
    Jun 2012
    13
    actually, here's the link . . . .
    Audi A4 2.0T FSI S LINE SPECIAL EDITION 4DR 2006
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,276
    Hi Camus, nice car, good spec as well. Thanks for sharing with us. x
    Nov 2008
    389
    If there was one fitted it would be in the glovebox. So looks like you'll need to fit one - either genuine Audi or 3rd party - Dension, X-carlink, Connects2 to name a few - All work in a similar fashion - pretend to be a CD-changer by plugging into the CD-changer port on rear of stereo...
    Enjoy the car
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Jun 2012
    13
    Thanks Phil - thought as much, and I am enjoying the car immensly!
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,467
    Quote Originally Posted by phil_w View Post
    And don't display album or track names, and reduce your iPod to 6 virtual CDs (the first 5 playlists, plus all files).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Mar 2011
    112
    Nice looking car, with good spec. Just one thing though, looking at the photos and its not that clear, but I thought that the Special Edition came with cross drilled front discs, these appear to be solid?
    Missed gear
    Jan 2006
    Kent
    385
    If it's a concert 2+ you can easily add an aux-in, code and run a cable around to the centre arm rest.
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
    StateOfPlay's Avatar
    2,226
    I got a parrot handsfree kit fitted with Ipod capability and it uses the BOSE sound system so ****ing well! It is ****ing awesome!
    Live your life as if nobody is watching you.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    653
    Quote Originally Posted by StateOfPlay View Post
    Also got parrot hands free installed on mine Does youre ipod connection just plug in the back of the HU still??? as i want to add one to mine. Mines the 6 disc Double din headunit
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Jun 2012
    13
    Haven't a clue what 'crossed drilled front discs' look like, are you suggesting it's not an SE? It has all the other SE stuff as far as I can tell.
    Mar 2011
    112
    Quote Originally Posted by Camus View Post
    Cross drilled have small holes through the disc as you look at it from the side, should be easily visible through the wheels.The holes help get rid of the gas that is produced under heavy braking that produce brake fade. NO, not suggesting it's not a Special Edition just may have had new discs at some time, just not the correct ones.
    One thing don't get confused by an S line Special Edition and an SE as they are two different models.
    Missed gear
    Jan 2006
    Kent
    385
    I thought the special edition was de-chromed and had different wheels - or is that the v2 and this is the v1?
    Nov 2008
    389
    Yep I think that was a bit later on maybe 57 plate and above. Maybe.
    May 2007
    33
    You should have a generation 2+ head unit, your best option is a Dension Gateway 300 GW33AC1. This allows you to navigate your ipod using the DIS display, MFSW and does show track name etc.
    Put GW33AC1 into Google and see the first youtube video.
    Jan 2011
    82
    looks like an s line se v1. the v2 were the ones with back grill and de chrome ect. can I quickly ask, being cheeky what you gave for it.. know it was up for that. I have the tdi 170 one and thinking of changing mine.
    Jun 2012
    13
    I traded in a Ford Mondeo ST TDCi and added £5,250. Been driving it non stop since Monday - its faultless. Well - apart from the fuel consumption: Im averaging 26mpg (was getting 40 mpg in the diesel Mondeo). The combined mpg is supposed to be 35, I have been mainly urban driving but am off to the lakes for a few days so will see if the steady motorway miles increase the mpg. But I guess I knew when I bought a 2.0T 220 bhp car it wasn't about the fuel economy!
    Mar 2011
    112
    Fuel consumption figures are not as good as Audi quote. I tend to average around 30mpg and a range of 420 miles from a tank full, however this is from a Quattro so would think you should see about a 10% improvement on that from a 2WD.
    Major service items (plugs, filters) are at 60k though have read better to change at 40k, also cambelt requires changing at 5yrs or 80k whichever comes first and not 8yrs, 115k as stated in service booklet, this was revised by Audi within the last few years.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,467
    Quote Originally Posted by be@st View Post
    You should have a generation 2+ head unit.
    It depends on when his 2006 model was built - early 2006 MY cars have Series II radios but later 2006 MY cars can have the Series II+ radios (even some early 2007 MY cars have Series II radios, my 2007 MY RS4 which was built in June 2006 came with a Symphony II and not a Symphony II+).
  1. Is there a way of having an iPod lead and cd changer connected at the same time?
    By Az in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2011, 10:29
  2. 2006 sportback ipod connection best kit?
    By seanick in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2010, 19:44
  3. Ipod Connectivity to A6 Allroad 2006
    By ph-allroad in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st March 2010, 04:11
  4. S3 Ipod connection and the IPhone 3GS
    By tspar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2009, 19:14
  5. RNS-E - worth the money? can you have ipod connectivity?
    By Duncan in forum In-Car Entertainment
    Last Post: 15th February 2009, 17:52
