Badger5Chris Nott
    Jun 2011
    245
    going into audi for recal
    just rang audi out of curiosity to see if my car has had the injector recall done and they said it needs to be inspected so going in next tuesday , just wandered as its remapped and dpf filter deleted will they still check and replace injectors if needed.
    cheers dav
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    822
    With a remap alone it will probably depend if the guy who inspects it does any checks on the ECU. They can tell if it's been altered which technically can invalidate your warranty so it's hit and miss. If the DPF has been removed then it's one more think they can pick up on and another excuse they can use to not pay for new injectors if necessary. I've read threads with people being refused work under warranty for not having FMDSH, but also read threads where people have modded cars and have no dealer SH and still get work done under warranty...
    Best thing to do it keep schtum and see what they say... you never know you can may not be affected by the recall
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Lee Applin
    this isnt warrenty this is a recall you will be fine
    Jun 2011
    245
    cheers guys yes its not a warranty job its a recall for possible defective parts .
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by davsa4 View Post
    Is this for a 2.0 TDI? Just a heads up, there's a new ECU update thats meant to be applied when the injectors are done although a lot of dealers aren't aware of it so you may be alright.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Jun 2011
    245
    cheers for the heads up max
  1. JUST BOOKED MY 2005 A4 2.0T INTO AUDI (COIL PACK RECALL)
    By jakeA42T in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th November 2011, 13:35
  2. Going Into Limp Mode
    By johnboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 17:55
  3. an audi for 100 bucks!!!!
    By PFunk_Spock in forum Classic Audi Forum
    Last Post: 21st December 2003, 20:55
  4. Thank Audi for Quattro/ESP
    By S3Bangs in forum General Chat
    Last Post: 10th January 2003, 09:26
