Sky InsuranceVolks Autos
    11
    AIR CON PROBLEMS
    Hi, just had aircon regassed and checked for leaks, all ok however the aircon is still blowing warm air.I dont think the compressor is kicking in. I have checked the fuse in the dash board but have seen on the forum that there is also a fuse on the top of the battery, i have looked but i dont have anything on top of the battery.( am i being thick? ) just wanted to know if i can do any simple checks before taking it to the stealers. thanks in advance for any advice.
    Jun 2012
    What model?,as far as i know most of the fuse of aircon is on the left side of dashboard,if it is left hand drive.
    outsideline's Avatar
    Dec 2011
    181
    if the gas pressure has dropped low and the car knows its dropped, then just by putting new gas in ( re-gas) doesnt make it blow cold.
    you need to tell the car its not working on low pressure now with a lap top and once you do that the car will blow cold air. bmw are a classic case for this. you must tell it whats it had to make the new part work if that makes sense.
    A4 b7 170bhp quattro | 210bhp remap from Rick @ UNICORN MOTORSPORT ( 07880558534) | DPF deleted | EGR deleted | 19" TSW Zolder 5 custom bronze wheels | rs4 grill | rs4 22mm rear sway bar | lamin-x head lights, fog lights, side repeaters | custom carbon wraped chrome window trims | E M Tuning LED conversion lights | genuine audi s4 rear valance | genuine audi s4 quad exhaust system to fit diesel | cupra R splitter | black audi ring badges | alpine headunit, hertz spl sub with JL audio amp |
    11
    Thanks for the replies will have to take to the garage i think its a bit beyond me .
    May 2012
    Norfolk
    118
    As you have no leaks and if your button is lighting up would get the high pressure / low pressure switches checked on the aircon system if they have gone down the aircon wont work
  1. Air Con Problems
    By WAL4D in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 21:39
  2. Air Con Problem: Slothlike coldness
    By hyperaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2006, 08:44
  3. Air Con Problem
    By Quattro_Lew in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2006, 21:54
  4. Air Con Problems A3 1.8 T Sport
    By jester104 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2006, 14:15
  5. Air Con-Problem
    By Jason in forum General Technical / How To
    Last Post: 22nd May 2006, 13:41
