Monster MotorsportVolks Autos
Results 1 to 29 of 29
    Jun 2011
    245
    one of those jobs you wish you had never started
    one door had a couple of minor scratches so flatted them out with 3000 wet and dry then machine polished , big mistake now it shows the rest of the paint work up , so
    a full day flatting both sides of car and 3 stage machine polishing then a coat of hd wax for good measure and the results will speak for themselves
    outsideline's Avatar
    Dec 2011
    181
    Fair play mate, but thats why i pay some one lol! Its so time consumeing isnt it. Looks mint though for all your hard work.
    Are those genuine black edition wheels??? More pics!
    A4 b7 170bhp quattro | 210bhp remap from Rick @ UNICORN MOTORSPORT ( 07880558534) | DPF deleted | EGR deleted | 19" TSW Zolder 5 custom bronze wheels | rs4 grill | rs4 22mm rear sway bar | lamin-x head lights, fog lights, side repeaters | custom carbon wraped chrome window trims | E M Tuning LED conversion lights | genuine audi s4 rear valance | genuine audi s4 quad exhaust system to fit diesel | cupra R splitter | black audi ring badges | alpine headunit, hertz spl sub with JL audio amp |
    Jun 2011
    245
    no mate they are just budget alloys
    Nov 2011
    171
    Looks fantastic mate ! Can i just ask what pad and polish combo you used ? My car is exactly the same as yours. I have just bought myself a Kestrel DAS-6 DA. I have 3 Menzerna pads (White, Yellow and Black) and i have Menz PO85RD 3.02 and PO85RD. I keep getting told that Audi paint is really tough so should i just hit it with the white compounding pad straight away ?
    Jun 2011
    245
    Hi Oddie yes the audi paint is very hard , i flatted all the panels with 3000 wet and dry then used 3m green pad with fast cut 3m polish ,followed by 3m yellow pad with 3m fine cut polish then black hole on a sonus black pad ,then waxed using autoglym hd wax ,but think i will be going over again with dodo blue velvet tomorrow if weather stays dry .
    cheers dav
    Nov 2011
    171
    So do you think i will get good results if i use the white compounding pad with the Menz Power finish and then use the yellow polishing pad with the final finish polish ? I was then planning on applying either AG HD wax or Harly wax using the black finishing pad ? Cheers
    Jun 2011
    245
    are you flatting or just compounding ,you will have to work the polish well to get swirls and rds (random deep scratches) out ,but steady away you cant really hurt the paint with a da it just takes a bit more effort ,would apply the hd wax by hand though not by da ,if you have any autoglym srp i would apply this with the black pad before waxing as it has slight fillers in for minor imperfection .
    Nov 2011
    171
    What do you mean by flatting ? Do you mean using wet and dry like you did ? If so then i don't really feel confident enough to give that a go at the moment so i will just be using the DA with the polishes. I have got tonnes of SRP, i normally use this to polish the car by hand.I didn't think about applying that with the black pad, sounds like a good idea though. Will it be ok to apply the SRP on top of the Menz polishes ?
    Jun 2011
    245
    yes mate i did mean wet and dry but as you say try the pads first i am sure you will be amazed by the results just dont rush it , are you going to clay the car first ,i would advise it as this stops and contamination on the paint getting into the pad, think you can get a starter clay kit from halfords for around £20 ,you will be surprised at the amount of crap on the paint no matter how clean your car is ,when applying the srp by da just run it a lowest speed setting working slowly ,
    Nov 2011
    171
    Yeah i will planning on claying it before hand anyway. I can't wait to give it a go now, just need a bit of decent weather !
    Thanks for your help and advice mate, enjoy the S Line
    scotty76's Avatar
    Nov 2011
    Berkshire
    805
    If you've not seen it there is a dedicated Detailing forum on here. Rock hard paint has been a discussion point this week. Head on over if you have questions: Detailing
    Jun 2011
    245
    well managed to get another coat of wax on it today and waxed wheels ect
    Nov 2011
    171
    Looks brilliant mate. I managed to get a bit of a go at mine although i had to stop half way through because of the rain. The results were quite good actually, especially considering it was my first attempt. I started on speed 1 to spread the polish and then moved up to speed 4 then 5 before dropping back down to speed 2 to finish off with. Does that sound ok ? And should i have used speed 6 ?
    Jul 2011
    Teesside
    327
    Quote Originally Posted by Oddie View Post
    Your fine not using speed setting 6. You did it the correct way, using 2 to spread the product then upping the speed to 4 or 5 is fine. I go no higher than setting 4 to work the product in. I find speeds 5 and 6 are slightly too fast, you lose the control a little.
    Nov 2011
    171
    Quote Originally Posted by JDM82 View Post
    Yeah, I felt a lot more confident and comfortable using it on speed 5. I am a little unsure whether i took enough time on each panel though. How much time should i spend buffing the polish in roughly ?
    Jun 2011
    245
    all depends on how the polish breaks down and condition of the paint you are correcting ,i spread on speed 1 then move to 4 to work the polish , find any higher the polish is removed before it has chance to do its job ,then back to 2 to finish it off.
    Nov 2011
    171
    Quote Originally Posted by davsa4 View Post
    Cheers mate. I can't wait to have another go at it, just need a dry day... all day !
    Jul 2011
    Teesside
    327
    I pass over the section I'm polishing in a side to side then up and down movement to ensure even coverage. I'll pass over around 8 times or more or until the product has totally broken down. I then wipe the section with a microfibre, if the product it worked in correctly, it should take no effort what so ever to wipe.
    Are you priming your pads before use?
    If not, priming is basically giving the pad your about to use a light mist of a quick detailer. This helps to lubricate the pad and ensures no dry pad is being worked over the paintwork.
    Nov 2011
    171
    That sounds pretty similar to what i was doing today. I did notice that the polish was really hard to wipe off on one of the panels, clearly this was because it hadn't been worked in enough. I wasn't priming the pads no, i will have a read up about that now. How often should i clean the pads ? After every time i use them ? And what is the best way to clean them ? Cheers folks
    Jul 2011
    Teesside
    327
    Yeah, clean the pads after every use. The best way is to a little washing up liquid, a little will do and make sure you throughly rinse the pads out, you don't want any soap left in the pads. There easy to wash.
    You can prime a pad by either a light mist of your pad with a quick detailer spray or you can use the product that your using the pad for. You simply apply the product to the pad and use your finger to cover the whole pad with the product. This ensures no dry pad and good lubrication.
    I use the quick detailer method. It less messy and quicker.
    If the polish was really hard to wipe off, you could have either not worked it well enough or your using too much product.
    This is a decent guide to have a read through: How to prime a foam pad when using a DA Polisher - Auto Geek Online Auto Detailing Forum
    Nov 2011
    171
    Thanks mate, really appreciated. To be honest i think i made a decent job of it considering it was my first go. The kit i bought was this one
    DAS-6 Dual Action Polisher - Menzerna Intro. Kit - Clean Your Car
    Would you say this is a decent combination to start with ? When i get a chance to spend all day on it i am planning on doing the following..
    PO85RD 3.02 via the white compounding pad, PO85RD via the yellow polishing pad, AutoGlym SRP via the black finishing pad, and then finally a coat of AG HD wax
    Jul 2011
    Teesside
    327
    Yeah the kit you have is a great starter kit. The good thing about DA polishers are there so safe to use and the results you can acheive are great. You will notice your results getting better as you become more experienced with the DA.
    The products your planning on using are fine, Menzerna make quality products, I'm not a big fan of AutoGlym to be honest. There's nothing wrong with them, I used to use there products but the more I got into detailing I realised there much better products out there for the same price. Im a big fan of Dodo Juice, Chemical Guys, Poorboy's etc etc but AutoGlym is fine too.
    Nov 2011
    171
    Ok thanks mate, your advice is much appreciated. I am well and truly hooked now, i keep looking outside thinking shall i just go and do a little bit more ?
    Jul 2011
    Teesside
    327
    If at any time your doing your car with the DA etc and you need to leave it for a while or over night, I sometimes break it up into 2 days when I'm doing a full detail.
    You should give the panels a quick wipe over with a quick detailer and a microfibre cloth. You'd be surprised how much air born contaminates and dust cling to your bodywork in such a short period of time.
    Just thought id mention it with you saying you have the urge to go out and do some more.
    Nov 2011
    171
    Don't worry, i stayed strong and decided to leave it. I am planning on spending a full day on it as soon as the weather allows
    Jun 2011
    245
    results like this make it all worth while but there was no way i was going out to video it so sorry for the quality through the window
    hd wax at work - YouTube
  28. #27
    Rastamouse's Avatar
    Welsh Audi Nut
    Aug 2011
    333
    Looks good,need to get mine done ( horrible swirls !! Grrr) started yesterday, washed,clay bar,wash again then bloody rain!!! Need some dry weather and some time to have my first go on my das-6 with menzerna polishes and cg hex logic pads. Any tips???
    rs4 grill with black wrapped surround,lowered 50/40 on weitec springs,rs4 fog grills,DRL headlights,18" rs4 alloys,Remapped to 175bhp, double din conversion with kenwood dnx7220 headunit,tinted windows,carbon wrapped interior,arm rest retrofit,Led interior lights,ambient light retrofit.Rs4 Pedals,Chrome wing mirrors.
  29. #28
    Aug 2011
    14
    Quote Originally Posted by Rastamouse View Post
    thats the exact same combination I used last year to detail my audi. Although the cg hex green pads cuts into the paintwork to remove the swirls when using menzerna power finish, I found it was still taking along time to acieve perfection due to the extrahard laquer. I achieved better results with the cg hex orange pad and powerfinish, then I went over with it to perfect it with a cg black pad and meguires polish with almost no cut followed by cg black hole then a wax. the results were stunning esp for my first go.
    Barrett
  30. #29
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    461
    car looks brilliant as usual mate, would love to see this in the flesh
  1. Replies: 12
    Last Post: 25th October 2011, 14:00
  2. Dont you wish you could do this sometimes?
    By Xmay4444 in forum You Tube Links
    Last Post: 22nd August 2009, 11:23
  3. Jobs you wish you'd paid someone else to do.
    By fatal8446 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2009, 17:53
  4. Name the one option you wish you had..?
    By silver75 in forum General Chat
    Last Post: 14th December 2006, 09:01
  5. Be Careful what you wish for!
    By jdp1962 in forum General Chat
    Last Post: 7th March 2006, 17:42
