EM TuningMonster Motorsport
Results 1 to 7 of 7
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Correct oil to use??
    As i only do short trips to work most of the year and change the oil every 4-6k miles im thinking of using 5w40 oil.
    Is Castrol Edge Engine Oil 5W40 A3 B4 Fully Synthetic
    Meets or exceeds industry specifications SAE 5W-40,ACEA A3/B3,A3/B4, C3,API SN/CF,VW 502 00/ 505 00,BMW Longlife-04,MB-Approval 229.3kg1/ 229.51,Porsche A40,Renault RN0700/ RN0710,Meets Fiat 9.55535-S2,Dexos2*
    Is this the correct oil to use????
    I understand the 5w40 bit to do with cold start and running temp viscosity. But dont get the other stuff????
    Probably just being thick but its worth asking im sure.
    Thanks in advance
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Apr 2012
    N. Wales, LL22
    1,224
    "VW 502 00/ 505 00"
    you want 507 really
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Apr 2012
    N. Wales, LL22
    1,224
    VCDS in North Wales
    rizzini7's Avatar
    Jun 2011
    728
    Ah yeah, had been using Comma 5w30 longlife. But i was planning on trying 5w40 this time. Only do about 10 miles a day when back and forward to work and had been reading that the thicker 40 is better for short drives and oil change intervals. Plus i do like to give the car some stick once shes upto temperature. The oil appears to be breaking down quite quickly and its only done about 4.5k also there appears to be abit of chain or tensioner rattle (which im looking into and hoping is an oil problem/blockage).
    So would i be better sticking to 5w30 or trying 5w40?
    If so is the 5w40 VW 502 00/ 505 00 correct???
    rizzini7's Avatar
    Jun 2011
    728
    Been looking around. Is COMMA SYNER-G FULLY SYNTHETIC 5W-40 vw 502.00/505.00 Ok to use?
    solaris's Avatar
    Slough, Berkshire
    404
    Been using Mobil 1 ESP 5W-30 ...5litres £39 great quality oil
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    rizzini7's Avatar
    Jun 2011
    728
    Its the 5w40 i want to try but not sure its the right spec or not. Plus mine holds rather alot of oil
  1. What oil to use in S3
    By corradoman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2007, 10:31
  2. What oil to use??
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2007, 12:43
  3. Best oil to use?
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2006, 16:21
  4. A3 130 diesel what oil to use?
    By A3-frankie in forum General Chat
    Last Post: 4th October 2006, 10:13
  5. what oil to use
    By katanwara in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 15:58
