Monster MotorsportVolks Autos
    Apr 2012
    LED Sidelight confusion
    This is most likely a common problem so hopefully someone can point me in the right direction.. I have put LED 501's in my b7 and at first everything seems fine with no dash board error. However the drivers side flashes after a few seconds and turns off. The confusing part is that normal LED's that throw up the error do not do this.
    Will the addition of resistors resolve this and if so what do I use??
    Any help is much appreciated
    Apr 2012
    Anyone???
    Nov 2011
    213
    I had the exact same issue with the ones I bought, the drivers side blinked 3 times and turned off.
    I just took them out and put the originals back in.
    Sep 2010
    Whitehaven, Cumbria
    59
    I had this trouble with mine. I changed them for these now work fine.
    ERROR FREE CANBUS W5W T10 501 LED SIDE LIGHT BULB 13SMD | eBay
    Nov 2011
    213
    Quote Originally Posted by THERMT View Post
    Do you have a picture with these fitted?
    The ones I bought from ebay the first time didn't really output much light, I was quite disappointed.
    Jan 2012
    KERNOW
    107
    I brought these
    They are really really bright and love the look they give the car. Unfortunitly they don't seem to last that long as i'm on second pair after the first ones fell apart in my headlight. I got another pairs sent free of charge and they started to fall apart last night!
    I'm now saving up for some new lights with DRL.
  1. Are LED sidelights legal?
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2006, 10:59
  2. LED sidelights
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2005, 19:59
  3. LED Sidelights and Xenons
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2005, 19:13
  4. Cheap LED sidelight bulbs - not impressed.
    By Little_Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 09:46
  5. LED sidelights
    By BobB in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2004, 09:26
