JMB RetrofitsSky Insurance
Results 1 to 10 of 10
    Apr 2011
    77
    S4 (B6) Headlight Warning is Weird - PLEASE HELP!!!
    Hi guys
    I have a 2005 B6 S4 Avant with a bit of an odd issue...
    The main beam nearside headlight was doing odd things. It would flicker on and off, and then switch off for 5-10 seconds before coming back on as normal. No pattern - completely random.
    So, I've replaced the bulb with a brand new one (Phillips or Osram, forget which), and now with 0 and 15 minutes of driving the warning light will come on the dashboard for that bulb.
    The bulb is now rock solid (no flickering etc) - but the damned warning light is now causing the issue.
    Any ideas at all as to what this could be???
    Many thanks!
    Apr 2011
    77
    Hi guys
    Sorry I screwed up. It's a B7 not B6. I'm going to re-post this in the B7 section.
    Sorry guys!!!
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    are they the standard buld set up or are they the self leveling super bright expensive ones ?
    Apr 2011
    77
    Hi there
    I don't think they are self-levelling, but it has Daytime Running Lights.
    Apr 2011
    77
    Oh, and bi-xenon. Takes D1S bulbs for main beam.
    Apr 2011
    77
    Hi guys
    Ok, have scanned with VAG COM and it's showing this fault:
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0304
    Coding: 11021
    Shop #: WSC 65536
    VCID: 3B714F18297E811
    1 Fault Found:
    02745 - Bulb for Daytime Running Light; Left
    30-00 - Open or Short to Plus
    Any ideas?????
    Many thanks!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Shall I move this to the B7 forum?
    That reads like your DRL bulb has gone.
    Aug 2010
    1,540
    it might be working but still have a high resistance somewhere? enough to trip the warning light.
    Apr 2011
    77
    Hi there
    Yes, can be moved to B7 forum no problem...
    I checked the daytime running light bulb and both and working fine.
    How do I check for resistance??
    27,094
    Take it you've actually cleared the fault 1st & cycled ignition & scanned again when car running & drl's/headlights on?
    If so then check the contacts for any corrosion 1st, try swapping bulbs around L to R etc.
  1. Please Help! A3 8L Headlights
    By AudiMafia in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2010, 21:57
  2. please help, strange warning sign
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2010, 19:32
  3. Weird Problem, Please Help Me!!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2009, 11:37
  4. A4 ABS Warning light on - please help!!!!!!
    By Big T in forum General Technical / How To
    Last Post: 20th February 2009, 10:55
  5. Headlight calamity! please help!?
    By jb7_uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st June 2005, 09:23
