AH FabricationsChris Nott
Thread: uneven idle
    May 2012
    87
    uneven idle
    hi i have an a4 tdi s line auto 2005,it has a very slight uneven idle,i have cleaned the egr valve and air intake,just wondered if there is anything else i can try?
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    When you say uneven idle, do you mean the engine doesn't tick over smoothly or there is a bit of a vibration that sort of comes and goes?
    Reason I ask is if its the latter, you may be in the early stages of DMF failure. If its vibrating slightly at idle, try dipping the clutch as its in mid vibration, and see if it improves slightly. If it is the DMF I hope you have a large wallet or an understanding bank manager.
    2012 RNSe Navigation Discs with unit software update. PM me.
    Suzuki GSX-R 750 K5
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
    May 2012
    87
    thanks-but as its an auto id be suprised if it had a dmf! lol
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Hmm, i must learn to read posts properly. Yes, you're right, ignore my post.
    Suzuki GSX-R 750 K5
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,907
    Quote Originally Posted by hubbo1 View Post
    Mine has.
    Try changing the fuel filter and have a good look for air leaks in the inlet hoses.
    One tip is to spray the hoses one at at a time with wd40 while the engine is running, if the idle goes up you have a leak on that hose.
    JSD 2.59
    Synergy-Solutions
  1. 2.0 TFSI - lumpy/ uneven idle after Timing Belt service & underboost fault!!!
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2010, 22:27
  2. A4 2.0L Diesel engine uneven running just above idle
    By neal.aldum in forum Diesel forum
    Last Post: 12th October 2009, 18:42
  3. Uneven and odd idling.
    By Eddie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2009, 21:56
  4. Uneven idle 2004 8P
    By SR71 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2009, 23:11
  5. a4 i.8 uneven idle
    By Mo-S3 in forum General Technical / How To
    Last Post: 10th August 2007, 09:01
